Home > Technical (L405) > Predicament
Page 2 of 3 <123>
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
@Baltic Blue
That's great, thanks for taking the time to attach the pictures, very much appreciated Thumbs Up 2011 TDV8 Vogue SE
Post #579285 11th Jan 2021 11:10am
A charger would be much more preferable... DONT start it to let it idle, leave it alone!
If you cant charge it then I would disconnect the battery if it's going to stand for a couple of months! (but check your door key/lock works first!)
And finally, if you only have the option to drive the car to charge the battery then I would drive it for at least 45mins to get a decent charge back in her... Don't forget every start equals 15mins driving! Thumbs Up
Post #579287 11th Jan 2021 11:13am
Baltic Blue
Thumbs Up , no problem I have just been in the garage and taken them, only to realise how dirty the carpet was under my rubber load mat. Rolling with laughter out with the vacuum before any of you eagle eyes comment Rolling with laughter
Post #579288 11th Jan 2021 11:16am
Rob99
Baltic Blue wrote:
Rob99,
You can’t use the accessories socket in the boot because it shuts down as the car goes to sleep.
I connect my Ctek to the main battery feed in the boot and that works well for me.
I leave this cable permanently connected, then just plug in the Ctek when required.
The lead easily passes out in the bottom corner of the lower tailgate without getting trapped.
Thanks Mike Thumbs Up
I'll be charging mine on the drive so I'll put the ctek just inside the tailgate. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #579567 13th Jan 2021 10:45am
Baltic Blue
That will be fine Rob..... the main advantage for me having the charger outside on the bumper is that I don’t need to open the tailgate to see the LED’s on the Ctek.... maybe you can see yours through the window ?
Post #579572 13th Jan 2021 11:29am
bishbosh10
Top tip from an idiot who knows, Whistle
If you have your car plugged into anything, then leave something memorable on the driver's seat to remind you to unplug it all before dragging the whole lot down the road behind you.... Laughing Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #579579 13th Jan 2021 1:03pm
Laughing classic...... ... - .- -.
Post #579585 13th Jan 2021 1:16pm
archermav
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
I have to talk wife into using mine for her drive to work every couple of weeks. Decent blast down the M6. Other wise it doesn't move, which after just paying £600 insurance is annoying Big Cry
Post #579618 13th Jan 2021 3:32pm
insurance,tax and warranty's all being wasted because most of us cant use ours...depressing Sad ... - .- -.
Post #579626 13th Jan 2021 4:06pm
Baltic Blue
Rolling with laughter Look on the bright side Stan, your fuel bill is down and the jabs on its way.
Post #579630 13th Jan 2021 4:37pm
only 2 fill ups since march 20 so saved a few bob Mike... ... - .- -.
Post #579631 13th Jan 2021 4:40pm
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
Bl4ckD0g wrote:
Gr4h4m wrote:
The noco charger I have had an odb2 socket adapter, works great for the time I need to charge it.
Do I read this correct; you charged your car using the OBD2 socket? I've never heard of anyone doing that, I must admit I wouldn't be comfortable doing that. I could have that wrong but there is way too much electronics linked in that area to use it for charging; I'd feel it is too easy to fry an ECU/module etc.
I just charge using the actual jumpstart point in any car if required. Or often even better if I cant get it in my garage, just take the battery out.
The power feed is fused on the obd port. It wouldn’t affect anything else. You could only trickle charge through it. Sub 5amps.
For that reason alone it wouldn’t really be worth while. Just connect to points under bonnet.
As above, as long as battery is kept charged, tyres inflated, everything else will be fine sitting. Starting, idling will have negative effect long term.
Post #579636 13th Jan 2021 6:03pm
The “site shop” tow bar adapter comes with a handy reminder card to put in the instrument binnacle. There is nothing that can't be fixed with a hammer😜😜
Post #579640 13th Jan 2021 6:34pm
Martin2
Wow, that really is low usage! I've only had mine since mid June and I've filled it up 17 times, although that is less than half the mileage I did in the same period last year. MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #579643 13th Jan 2021 6:55pm
jackcramerr
I hope you guys have consulted the relevant manual and not just blindly hooking up a charger to any point that is convenient.
If not you are playing with fire. There is a reason there is a designated point for charging (under the bonnet).
Post #579780 14th Jan 2021 7:10pm
Page 2 of 3 <123>
