Home > General (L405) > hello everyone
aguiness
United Kingdom 2017 Range Rover Vogue SE TDV6 Aruba
hello everyone
Hi i am new to the forum
i am thinking of buying a 2017 vogue se
its done 22k miles but the all the discs and brake pipes were on an advisory on the mot
is this normal after that low milage or is it because its been sitting around
thanks
Bow down
Post #579600 13th Jan 2021 2:20pm
CS
My 2017 MY with 28,000 miles was checked and the brake lines were OK, though scoring on inside of front discs with suggestion these be replaced when the pads are changed. But my 2012 WM had a brake line corrosion advisory when about three to four years old, it was treated with Dinitrol or the like and was then OK during the rest of my ownership. So it is unusual to have corrosion advisories at that age, but not outstandingly so, especially if it is (say) a car that spends a lot of time outside on the coast and is constantly exposed to salt. Scottish cars in general will be worse for corrosion, probably worse now with the lockdown this year and last.
My impression is that LR's approach to protecting vehicles from corrosion is to look at the average use worldwide, and not to go to the expense of protecting cars in higher corrosion countries, Scotland is probably about the worst place. Only Range Rovers since 1988
Post #579605 13th Jan 2021 3:00pm
rjff
What exactly did the advisory say?
ISTR that you can get one if the pipes are coated with a grease for protection as the tester is not allowed to clean to inspect. Cheers
Richard
Gap IIDBT
Post #584217 17th Feb 2021 9:59pm
If its Sotlandish then yes a 17my FF might need brake pipes changing! Not too unusual...
Post #584237 18th Feb 2021 12:41am
