Home > Maintenance & Mods (L322) > 4.4 TDV8 EGR and DPF removal
Page 1 of 14 123 ... 121314>
DrRob
I've seen a few posts on Facebook and on here about removal of EGR and DPF on the 4.4 but there is a lot of cloak and daggers about it....
Thought it might be a good excuse to start a thread to capture any findings, thoughts and hopefully some solutions!
No comments on the legality of it....not what this thread is about. Talk to my lawyer (SWMBO) Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #579559 13th Jan 2021 11:31am
Bluespanner
United Kingdom 2012 Range Rover Vogue SE TDV8 Baltic Blue
Mine is chipped and had the EGR valves done at the same time. At the moment DPF is still working, apparently it should be cleaner now there is no EGR anyway. Don’t know how right that is but if they go wrong I’ll get the dpf deleted too. All easy enough according to my man :thumbup:
Post #579593 13th Jan 2021 2:52pm
mjdronfield
I think I’m right in saying that if you are going to do it, you need to do both? As egrs do something with the temperature when doing a DPF regen.....
Though as above, it may not be necessary to do both.
Would be a cracking engine without the strangulation of emissions gubbins..... 🤣
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #579597 13th Jan 2021 3:05pm
Bluespanner
The other bonus with no EGR is that there’s no more hot gas to blow holes in your rubbish plastic intake manifold 👍
Post #579608 13th Jan 2021 4:10pm
Baltic Blue
Rob,
Just for your info, some foreign market 4.4tdV8’s were produced without the DPF fitted.
If you look in the exhaust section of the WM their are pictures and details, but I guess they are few and far in numbers.
Post #579619 13th Jan 2021 4:35pm
DrRob
Personally I'd like no EGR and no DPF.
I thought the DPF needed the EGR but it's all black magic to me (no pun intended with reference to colour of soot!) Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #579621 13th Jan 2021 4:43pm
t5pete
Very interesting topic and I suppose in theory removing both eliminates complications of leaving one of them in the system.
Post #579647 13th Jan 2021 9:03pm
mjdronfield
https://www.sltremapping.com/tuning/land-r...tdv8-310hp
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #579652 13th Jan 2021 9:58pm
Dolphinboy
@MJD
how much for the remap?
Post #579666 13th Jan 2021 10:51pm
mjdronfield
I don’t know mate, I didn’t click any further, I only did a Google search for 4.4 TDV8 DPF removal.
So it is commercially available if you feel the need to do it.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #579670 13th Jan 2021 11:12pm
GrunterNI
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
I only bought my 2007 3.6 in October past and left it into my local indy for a thorough check over as it is my first RR. Whilst there I asked about remapping and EGR blanking or removal.
He was all for remapping as they do a full diagnostic and mechanical appraisal first and if all is ok they do the remap with a 12 month back up should anything go bang. If I remember correctly it costs £250ish for the remap which takes the bhp up to 310ish but I cant remember the torque figure.
As for the EGR's he said that blanking them is not recommended as it causes overheating issues on these engines but they can be electronically deleted along with the DPF's but again he didnt recommend it. On past cars I have nearly always blanked the EGR's without any issues as they have always been a source of problems as engines start to get more and more mileage on them so I dont understand why it cant be done on these engines. Are they really that over engineered and complex?
Has anyone blanked their EGR's successfully or does it cause overheating issues?
Post #579675 13th Jan 2021 11:56pm
GraemeS
Australia
Oz 4.4 L322s don't have a DPF.
EGR valves get closed by engine management when performing a DPF regen so that ALL the fuel-rich exhaust gas goes to the catalytic converter that needs the fuel to get hot enough to burn the soot accumulated in the DPF.
I blocked my 4.4's EGR pipe which made light throttle nicely responsive but as soon as the throttle was backed-off the ecm closed the EGR butterfly trying to cause more exhaust gas recirculation to lower emissions but with EGR blocked the engine almost stalled, so the EGR pipe had to be unblocked. I look forward to having EGR mapped-out.
Post #579687 14th Jan 2021 2:51am
DrRob
GrunterNI wrote:
I only bought my 2007 3.6 in October past and left it into my local indy for a thorough check over as it is my first RR. Whilst there I asked about remapping and EGR blanking or removal. Has anyone blanked their EGR's successfully or does it cause overheating issues?
Hi there. Yours has the 3.6 which is a totally different set up to the 4.4. There is a thread in the Wiki for the 3.6.
Answer is yes, you can with a £40 kit and very successfully too. You may not even need it digitally deleting for a 2007 car.
If we can keep this thread for the 4.4 please Bow down Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #579693 14th Jan 2021 9:19am
DrRob
I've emailed one of their local dealers. Click on the dealers tab at top and put in post code.
https://www.sltremapping.com/dealers
I've asked how they do EGR and DPF delete and the costs....
Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #579694 14th Jan 2021 9:23am
kevinp
Looking at your next post with anticipation Rob. I would love to be able to boot mine from a stand still and for it to go forwards. Lol.
Post #579712 14th Jan 2021 11:06am
