![]() | Home > Technical (L405) > SDV8 dipstick looking thing |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7906 ![]() ![]() ![]() |
I believe that’s where they extract the oil, when doing an oil change. Might be wrong.... that could be the other side.....
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Oil extraction tube for engine oil. A vacuum pump attaches there after the cap is removed by pressing down and turning anticlockwise.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Yep, oil extraction tube sir |
154JON Member Since: 31 Mar 2019 Location: Essex Posts: 131 ![]() ![]() ![]() |
Thanks Gents for the quick answers and that will come in very handy in the future |
That's the puppy that I have...great bit of kit. Not cheap but very very easy to use!
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3817 ![]() ![]() ![]() |
Easiest, cleanest , quickest , oil change you will ever do. Mike. G reg 2.5VM Vogue Portofino red 1991- 1999 V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
Thanks for those pictures if I had a dipstick as well I would be over the moon. |
