Home > Technical (L405) > P050F Brake Vacuum - DPF Full -
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
Got an L405 V6 which constantly complains DPF full. Only reoccurring fault code is P040F Brake Assist Vacuum too low and P246B Vehicle conditions incorrect for dpf regen.
I am assuming the latter is a result of the brake vacuum fault.
Anyone had similar? I know the earlier sports had this issue. [/u]
Post #579533 13th Jan 2021 12:13am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
Fix the vacume issue then conditions will be right for a re-gen Thumbs Up 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #579554 13th Jan 2021 11:08am
JNC
Fully my intention. My question however is if this is a known issue before I start digging deeper into the vehicle.
Post #579555 13th Jan 2021 11:12am
