Home > Technical (L405) > Predicament
Page 1 of 3 123>
goddo
Predicament
Morning All, I hope you are all keeping Covid free and safe?
I have a predicament with my L405 3litre diesel V6.
It's not getting driven at all at the moment as I have no valid reason to go anywhere.
I don't want to abandon the car but if I do as previously mentioned, which is start it up and leave it idling, it gets the oil circulating round the engine but surely the DPF is getting sooted up and causing more of a problem?
What would you do? Just leave a trickle charger (Ctech MXS 5) connected or start the engine every now and then? Or both?
Thanks for any advice
Post #579171 10th Jan 2021 12:00pm
Baltic Blue
I am sure lots of us are in exactly the same quandary.
B.B. has been stood in my garage since Christmas Day, when I last took it out for a decent run.
The green lamp on stage 7 of my Ctek 5 is glowing, showing fully charged, but it is stoned cold, so obviously not drawing any charging current, so at least for the present I am just leaving it connected.
Post #579173 10th Jan 2021 12:15pm
Maccaa
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
There is a school of though that suggests just letting a car idle, doesn't stress the engine enough to properly attain working temperature and therefore can create more problems than it protects agains.
My M3 sits in the garage from October to spring with the CTEK left on...... and I never start it until its ready for a proper run Smile and I've had the car 6 years. Current FF Westminster 4.4 V8
Post #579181 10th Jan 2021 1:47pm
Gr4h4m
United Kingdom 2010 Range Rover Vogue SE 4.4 V8 Santorini Black
Noco is a good alternative to a ctek but cheaper. I swapped when my ctek gave up the ghost
Post #579188 10th Jan 2021 2:54pm
AndyS
The lockdown won't be that long so just leave on trickle charger, it won't do it any harm. Occasionally starting and not driving will create condensation and then corrosion internally over time.
If you do start it make sure you go for a decent run out.
Post #579194 10th Jan 2021 4:39pm
Leave it alone, leave it plugged in. Not doing any harm sitting. Repeatedly starting and not allowing the engine to come up to temp fully will cause more problems.
As above my M3 had been sat in my garage since November, not moved or started it it’s just plugged into the ctek There is nothing that can't be fixed with a hammer😜😜
Post #579197 10th Jan 2021 5:12pm
DrRob
Ctek it. Job done.
Do mine weekly via towing socket adaptor off the shop Thumbs Up Superb piece of kit Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #579208 10th Jan 2021 6:16pm
Rob99
As I don't have tow electrics, is it possible to connect my ctek to the accessory socket in the boot?
Or should I connect it to the main battery cable that comes into the RH rear cubby? 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #579261 10th Jan 2021 11:52pm
Gr4h4m
The noco charger I have had an odb2 socket adapter, works great for the time I need to charge it.
Post #579264 11th Jan 2021 1:41am
goddo
I just connect my charger directly to the battery in the boot using the ctek adaptor. The charger sits on top of the spare wheel and the extension lead cable passes through the tailgate lids quite comfortably.
Post #579265 11th Jan 2021 4:00am
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Do I read this correct; you charged your car using the OBD2 socket? I've never heard of anyone doing that, I must admit I wouldn't be comfortable doing that. I could have that wrong but there is way too much electronics linked in that area to use it for charging; I'd feel it is too easy to fry an ECU/module etc.
I just charge using the actual jumpstart point in any car if required. Or often even better if I cant get it in my garage, just take the battery out.
Post #579267 11th Jan 2021 7:15am
Baltic Blue
Rob99,
You can’t use the accessories socket in the boot because it shuts down as the car goes to sleep.
I connect my Ctek to the main battery feed in the boot and that works well for me.
I leave this cable permanently connected, then just plug in the Ctek when required.
The lead easily passes out in the bottom corner of the lower tailgate without getting trapped.
Post #579270 11th Jan 2021 8:43am
TJH1985
We are just swopping our cars around as my other half is still going to work, but as above leaving it say for a few weeks feels better than starting without going for a good run! Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #579273 11th Jan 2021 9:36am
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
@Baltic Blue - Where would I find the main battery feed in the boot? 2011 TDV8 Vogue SE
Post #579275 11th Jan 2021 10:10am
Baltic Blue
Dennij,
Just a couple of seconds to remove the drivers side cubby hole cover and all is revealed
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #579280 11th Jan 2021 10:56am
Page 1 of 3 123>
