Home > Technical (L405) > Pre-Heat Car - cold mornings
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
Hello
So today it was -7 when I went to the car. I had presses the remote heater button about 30 minutes before. I could see the LEd flashing every few seconds. But when I got to the car i could see the car had warmed up a bit, but it had stopped before I got in.
I could see a small spot on the windscreen had cleared I am talking 1or 2 cm
In my last car in that time the same time the inside of the car was even getting warm and the blower was running air on to the screen
Am I doing something wrong or am I expecting to much...
Thanks SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #579266 11th Jan 2021 5:56am
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
is this on the the 2020 vehicle in your signature? 2010 VSE [Roger]
Post #579274 11th Jan 2021 9:48am
luxmoggy
Yes... As I hadn't driven the car for a couple of days I couldn't use the app. So I used the remote... SDV8 AB MY 2020
Post #579286 11th Jan 2021 11:12am
luxmoggy
The car salesman said it could be the battery. So I am connecting the CTech charger overnight.
It could be correct as on the connector I attached to the battery posts is flashing red. I will see where I am in the morning. SDV8 AB MY 2020
Post #579433 12th Jan 2021 2:05pm
Martin2
Mine did the same after not using the car much for a couple of weeks other than local journeys and I believe it switches off to protect the battery, a low battery would make sense. MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #579440 12th Jan 2021 2:38pm
knwatkins
I agree with the above. It does sound like the battery. Please report back after you've charged it up. It will be interesting to know if charging resolved the issue. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #579508 12th Jan 2021 8:25pm
