Home > For Sale & Wanted > [Wanted] Bumper OS Headlight OS wing
Ianclark1275
Hi There,
WANTED
ive been using my RR for work and long story short i need a front bumper, OS front Wing and OS Headlight
Headlight turns with steering wheel and has side lights that come on and off in corners
Wing and Bumper standard L322 2011 4.4 AB.
Santorini Black but likely will be repainted.
Ebay has a few buts but would rather help someone out on here after the help i've received from here.
Thanks
Post #579262 11th Jan 2021 1:54am
Xray charlie
England 2003 Range Rover Vogue 4.4 V8 Giverny Green
I have o/s wing from my 2003 Giverny green car available if it helps.
Post #579449 12th Jan 2021 4:45pm
Rodjules
United Kingdom 2015 Range Rover Vogue SE SDV8 Causeway Grey
Headlight
Not sure if this will help but if its just the headlight plastic lens you need these are available for the facelift headlights from
Powerful UK and offer a significant saving over a replacement unit ? Just need to put your light in the oven to heat up the sealer a relatively easy job (there's a youtube clip on how to do the discovery headlights) same process. 2015 L405 Range Rover 4.4Sdv8 Vogue SE, Baltic Blue, Ivory
2012 L322 Range Rover 4.4 Westminster Baltic Blue, Ivory - Deceased
2012 Discovery 4 HSE 3.0 Sdv6 Oslo Grey, Black - Gone
2006 L322 Range Rover Td6 Vogue SE Buckingham Blue, Parchment - Gone
1996 P38 Range Rover 4.6 HSE Rioja Red, Black - Gone
1990 Landrover 110 2.5TD CSW - Why Oh Why ???
Post #579461 12th Jan 2021 6:11pm
Ianclark1275
. hi mate there appears to be a difference in the lower section for later cars - thanks anyway
Post #579501 12th Jan 2021 9:01pm
Ianclark1275
Re: Headlight
. hi there first thing i did was order one, its in the shed and i havent had the time to take off the headlight as the bumoer is a bit mangled and i thought you had to remove the bumoer to get head light out? anyway i have one in case that works Wink
Post #579502 12th Jan 2021 9:05pm
Ive certainly got a bumper, may also have a wing & may even have a light?
Ill have a look tomorrow, PM me to remind me if you don't get a response sir Thumbs Up
Post #579521 12th Jan 2021 10:43pm
Ianclark1275
That would be great thanks
Post #579534 13th Jan 2021 12:29am
Ianclark1275
thanks to the fourm members i have a bumper - in black
ive also ordered a genuine second hand wing - in black £80
just need fog surround and clip fro wing to bumper which i can get new no bother
Still looking for a Headlight tho.......
Post #581511 28th Jan 2021 6:00pm
Ianclark1275
Just an update - i have everything except the headlight
the part number is LR026144 RHD Adaptive
retail is £1600 each.
Ebay lights are LHD or non adaptive or damaged
if anyone has one let me know thanks
IC
Post #583949 15th Feb 2021 11:24pm
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
Bloke on FB breaking a 60 plate;
Wants £900 for the pair.
https://m.facebook.com/groups/424975264283...054779368/
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #583955 16th Feb 2021 12:49am
Ianclark1275
Thanks - Yeah, I’ve asked the question if they are adaptive or not - no reply
The inserts around the light on 2010 are grey mine are black...
Post #583970 16th Feb 2021 9:47am
RRDunc
Ah....yes, mine are black too.
If I come across any I'll let you know.
Post #583982 16th Feb 2021 12:21pm
