Home > Maintenance & Mods (L322) > Headlamp washers
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Headlamp washers
Mot due next week and headlamp washers not working. Thought they might be frozen or low on washer fluid. Topped the fluid up and it is “weeping” out of both washers so not frozen and pipes connected
Cant see in the handbook if there is a separate fuse for headlamp washer pump.
Does anyone know where the pump is located?
Thanks 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #578511 5th Jan 2021 1:25pm
V8 Bob
Found a good video showing location so just need to check if it is a separate fuse. Front and rear washers are separate fuses but no mention of headlight one. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Post #578514 5th Jan 2021 1:44pm
ChrisRRV
United Kingdom 2004 Range Rover Vogue 4.4 V8 Tonga Green
Can anyone advise for the facelift conversion 04 to 09 what washer pump do I need to buy and also wheres the best place to wire it into? Just for MOT's
Post #578645 6th Jan 2021 2:21pm
kevinp
If you can't get it sorted in time for your MOT could you just prise out the jets from the bumper and put in some temporary grommets?
Post #578652 6th Jan 2021 2:46pm
V8 Bob
Ordered a new pump from Island 4x4 yesterday afternoon .just been delivered at lunchtime excellent service.
Hopefully not the relay causing the issue, if it is I will connect it in alongside the main windscreen washer as a temporary fix so it will work every time.
Need the car in the morning so will leave till tomorrow afternoon 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Post #578653 6th Jan 2021 2:52pm
V8 Bob
So put it in the garage last night as it’s been very cold up here overnight.
Woke up to 8” of snow!
Followed video and all changed and working fine...lessons learned?
1 clip tool is very handy I ordered one when I watched video. 5 small clips at front bottom of wheel liner are of the type that has a plastic plug in centre to push lugs out.
2. FFRR washer bottle holds a lot of water. Mine was full as I wanted to check it wasn’t a level issue it filled 3/4 of a bucket!
3. Wear water proof leggings as when you pull old pump off the water from the reservoir shoots out a long way, fortunately due to the snow I had some on otherwise I would have been soaked.
Drivers door window had frozen and had refused to drop more than 5mm fior a week or more, overnight in garage it thawed out and now works fine.
And don’t forget to put an axle stand underneath while you have a wheel off for safety 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Post #578977 8th Jan 2021 3:01pm
