![]() | Home > Technical (L322) > Gearbox |
Sam Member Since: 02 Jun 2017 Location: West Sussex Posts: 89 ![]() ![]() |
May well be the dreaded lock up clutch failure. Basically the symptoms are if under acceleration it feels like you’re driving over a cattle grid then that’s basically it. Worse case scenario is a gearbox out and repair, but you might get away with a fluid change.
Simon_CSK Member Since: 13 Feb 2020 Location: Ayrshire Posts: 132 ![]() ![]() ![]() |
Did about 30 miles in it mostly motorway. But yes on full throttle it was like a cattle grid. The car has only done 79500 miles. Hopefully the flush and filter change will cure it. Have noticed that it isn't holding in park either. Current cars
Hello Simon, yep, that’s pretty symptomatic. As I say, you may be lucky with a fluid and filter change or two, certainly worth doing that before anyone tries to convince you to let them take the box out.
I bought the car with 72k on it was going to sell it with 80k as I do far to many miles and don't want to waste that one. Will make on it even if I need to change the gearbox but that isn't the point. Really want a 2011 or later L322 for my collection lol.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1804 ![]() ![]() |
Is the gear lever tight to move? Does reverse engage OK? |
No difference in the lever at all.
Sam Spot on thanks. Changed the gear oil and the filter this afternoon and it is running much smoother. The other thing I have noticed is an improvement in the MPG. Current cars Range Rover Sport HSE TDV8 Range Rover TDV8 Vogue Range Rover P38 Vogue Range Rover CSK Discovery 3 HSE |
Nice one Simon, really pleased for you that you managed to get it sorted. Just keep an eye on it and of you do decide to keep it for a while longer remember to do a second fluid and filter change in another 5k or so. |
San it needs to move on I have far too many cars for my own good. Current cars
Know what you mean Simon, back in the summer we had an L322, Disco 4, Audi Q3, Lancia Fulvia coupe, and (Of all things), a Dodge Viper......(long story).
Sam
Wow, that's a lot of iron! Nice collection. I'm really please with the D4 and did toy with replacing the L322 with a very late 4.4, but the Mrs was always shy of driving the old one and the amount of long distance trips we do (Did!) meant the extra economy from the D4 was a factor.
The classic is a CSK so only a resto on that. One of the D2's I am breaking I put a Galvanised chassis on and made it into a very capable car. Tow bars front and back with receivers to take a removable winch and power outlets front and back. Very capable but never used it off road. It was very useful tho and want a D3 or 4 for the same purpose. The D2 that is being sold is a 3.9v8 Auto and a very nice car with only 92k on it.
That's the trouble isn't it? There are so many readily available parts to either keep standard or modify, it's easy to keep buying projects to play around with. Like the idea of a petrol 110 to fiddle with but they hold their value so well even a rusty old heap can be £10k. Will get one sooner or later though. A V8 preferably but a 2.25 if not as the 2.6 is so hard to extract much power from (You can actually get more from a 2.25 of you take it out to 2.5), and the 2.6's have a serious drink problem. All good fun though, and good luck with your projects. |
