Home > Technical (L322) > IID Engine Live Values not showing
Sonearly
Not sure if I am doing something wrong but cannot find live values for the Engine. Was trying to get DPF information. Have definitely seen them before but nothing now. I have no option for Engine Values at all.
Any ideas please
Post #578251 3rd Jan 2021 3:21pm
Dolphinboy
Go into first page, look for Live Values, select live values, then Complete List, then PCM-Engine TDV8.
Post #578267 3rd Jan 2021 4:29pm
Sonearly
Many thanks, found it , but when I select view and look it shows
Soot concentration
Remaining Volume
Number of successful regenerations
Number of partial successful regenerations
All as N/A
Sure I’m doing something wrong, help please
Post #578305 3rd Jan 2021 8:46pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
You need to choose the soot concentration inferred option if you want to check your soot level. Ignition need to be on in order to see the reading 2011 TDV8 Vogue SE
Post #578317 3rd Jan 2021 9:43pm
Sonearly
Yep done that , still coming up as N/A
Any more clues anyone ?
Post #578330 3rd Jan 2021 11:01pm
Dolphinboy
How old is your IID? Has it had all the software upgrades?
Post #578334 3rd Jan 2021 11:29pm
Sonearly
IID is two months old. Have had them showing in the past, will check updates and try again
Post #578339 3rd Jan 2021 11:40pm
dennij
You could try reflashing the firmware using the IID Updater tool. It will probably tell you that you already have the latest version if your unit is only 2 months old but it won't hurt to reflash it just to make sure all the software on the IID has installed properly 2011 TDV8 Vogue SE
Post #578361 4th Jan 2021 7:38am
Sonearly
Thanks for everyone’s help.
Advice was spot on. I re run update and it was out of date. All working now.
Post #578388 4th Jan 2021 11:55am
