Home > Technical (L322) > Whirring noise from engine (possibly LH side) 4.4 TDV8
cadoganpier
United Kingdom 2018 Range Rover Autobiography SDV8 Loire Blue
My 2012 TDV8 makes a whirring noise that rises and falls with engine revs, not road speed. It does it with the car in neutral and at a standstill as well as when moving in gear. It sounds like a sort of noisy diff kind of sound but the fact it does it at stand still precludes that?, could it be belts/tensioners?, any ideas greatly welcomed.
Post #498942 17th Dec 2018 5:12pm
Sonearly
Would be interested if this got resolved
Post #578253 3rd Jan 2021 3:24pm
4434Morrison
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
Also interested in following this thread as I have a similar noise. 2012 4.4 TDV8 Vogue SE Current
2015 E220 with AMG Sport Pack - Currently driven by my son
2010 3.6 TDV8 Vogue - Written off by my son
Post #578279 3rd Jan 2021 5:11pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
Water Pump bearings maybe?
do you have a very long screwdriver?
if you do you may be able to have a listen but be very carful 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #578281 3rd Jan 2021 6:08pm
Sonearly
Have replaced belt tensioner and three of the idler pulleys as they were showing wear. I have a stethoscope type of tool I’ll see if I can get to water pump in the morning and give it a go.
The best way to describe it is like a scalextrix car motor. It’s there both in neutral and when driving.
Post #578301 3rd Jan 2021 8:13pm
coopss
I noticed something like this after a service. I’ve not noticed it outside, only in the cabin. Same scenarios are you’ve described 1995 4.6 v8, green/tan (long gone)
2005 4.8iS X5, blue/black
2011 4.4 tdv8, black/black (gone)
2003 3.0d X5, Oxford green/black/manual
2021 p575 SVR, BR green/vintage tan
Post #578316 3rd Jan 2021 9:39pm
Sonearly
Same as mine, can’t hear it when seated in the back. Still got an annoying whine coming from the front drivers seat, which I know is very expensive to replace, should have checked before marrying her. Thank god she never reads this.
Will feedback in the morning after checking water pump.
Post #578318 3rd Jan 2021 9:46pm
Sonearly
Water pump seems fine. Will try releasing belt and running without to try and eliminate idler pulleys and ancillary components. Definitely seems to be less responsive on first start up in this colder weather for a couple of minutes, but it might just be paranoia.
Post #578389 4th Jan 2021 12:00pm
Sonearly
Hi
Been under the car today fitting mud flaps. Whilst fitting offside front noticed bolt missing from corner of gearbox/engine protection plate. Very springy and vibrates significantly. Did not have correct bolt and loosely fitted what screw I had, couldn’t do up completely tight, but the droning has reduced dramatically. Will acquire correct fitting screw as soon as somewhere open, but looks like possible fix.
Post #579123 9th Jan 2021 10:15pm
coopss
That’s interesting - do you have a picture of the part? 1995 4.6 v8, green/tan (long gone)
Post #579137 10th Jan 2021 7:26am
Sonearly
You have two under engine shields that cover whole area. You can’t miss them. My issue was with the back one that was missing screw. Worth checking all of it for missing fixings.
Post #579143 10th Jan 2021 9:14am
Jayk69
That would be a nice find and a good fix!
as for the cold start mine seems to rev more during the very cold mornings -1 to -4 no issues starting though.
I might yank the MAF's and temp sensors and run some electrical cleaner over them i doubt they have ever been done.
But i think it is normal as soon as temp builds runs like it always has!!
I had a jeep grand cherokee a good few years ago now used to put plumes of black smoke out the back when hot. anyhow after months of hunting for the cause i changed the MAF and intake temp sensor, when i started the car you should of heard it clicking and rough running it cut out, i managed to start it then it coughed and spluttered clicked once more and the engine just went smooth and very quiet. That cured the black smoke and the car just ran great after that it had never ran better!! 2012 Vogue 4.4 TDV8 - Current
Post #579180 10th Jan 2021 1:24pm
