![]() | Home > Technical (L322) > No centre diff lock? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7912 ![]() ![]() ![]() |
Locks itself on the L322. It’s the locking rear diff that was optional.... standard on some models I think.
gravitylover Member Since: 08 Nov 2020 Location: Southeast NY Posts: 36 ![]() ![]() ![]() |
Do all L322's have an auto locking center diff? How does it know when to lock up? I have a locking rear and am curious how that knows also. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
Even my 1989 classic had a viscous coupled centre diff....
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Depends on the transfer box,
The RR Bandit Member Since: 31 Oct 2019 Location: Teesside Posts: 29 ![]() ![]() ![]() |
I always assumed that these open lock symbols would change to a closed lock symbol in the event that the diff actually activated.
They turn orange when locked, iirc, you have a dd295 centre box which will fully
Even if you don’t have a rear locking diff, you will still have the padlock symbol on your 4x4 display, but it will never change colour to indicate it’s locked.....
Never saw the rear lock symbol on mine Mark. Only the centre. Never had cause to use rock crawl tho.... There is nothing that can't be fixed with a hammer😜😜
I’m going from memory, so that’s never 100% 🤣
Looks like a £625 option on later ones....
Manual doesn’t really help as to whether it’s still shown if not fitted....
HS66 Member Since: 22 Jun 2016 Location: Surrey Posts: 73 ![]() ![]() ![]() |
I don’t think my 4x4 info display even has the locks on it but I will have a look later, it’s an early 2007 TDV8.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8546 ![]() ![]() ![]() |
They found that people used them too much and then not when needed... Use them when not needed and you can easily damage part of the system, forget to lock them when you do need it and the pictures get on youtube showing a Rangie off at it's worse!!
