Home > Maintenance & Mods (L322) > Sun Roof Seal
Ricardo Villa
United Kingdom 2009 Range Rover Vogue TDV8 Bournville
Sun Roof Seal
Just noticed Seal has small slight "lift" to it, see pics. Not sure if frost has got underneath or it was always like since I bought it. No sign of any ingress, what's best fix? Can wait till it's warmer and maybe push down but it's cold and maybe brittle at the mo. Can run some sealant along it then? Any tips appreciated.
 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
2005 Jaguar XJ350 3.0 V6 Sovereign, Jaguar Racing Green, Ivory
1997 TVR Chimaera 450, Formula Red, Grey
Post #577878 31st Dec 2020 1:49pm
Looks like it’s been caught on something at some point, or it’s been through the monkey enclosure at a safari park......
It seems to have some discolouration so I would imagine it’s been like that a while, if it’s not leaking then I wouldn’t worry too much about getting it done today, just make sure your sun roof drains are clear so any water which does get in is able to flow away. There is nothing that can't be fixed with a hammer😜😜
Post #577881 31st Dec 2020 2:03pm
Ricardo Villa
Thanks, Yes I thought it looks like a snag somewhere. Is the Seal replaceable or is it best just to "patch" up? 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Post #577882 31st Dec 2020 2:10pm
i should imagine it would be a lot of work to replace that seal, i would dry it out and glue or put sealant in it... ... - .- -.
Post #577883 31st Dec 2020 2:12pm
Ricardo Villa
Thanks, yes looks a bit of a specialist/expensive job, will sort out when temperature increases! 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Post #577897 31st Dec 2020 4:17pm
Wrecker79
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi Ricardo,
I had the same issue on my L322 when I carelessly backed out from under a partially closed garage door with the sunroof tilted.
The sunroof glass itself has a triangular section bonded onto the edge of the glass to which the seal is slotted - see the attached diagrame.
WIth the roof tilted, clean around the exposed parts and you should be able to push the seal back into place - do it on a warm day, though! (actually, this is a serious comment - the surrounding seal is quite stiff, so to avoid damage it would be better on a warm day)
Good luck!
W.
 2017 - L405 SC - WOW! just WOW!
2014 - L405 4.4
2010 - L322 3.6 - Carried me 100,581 miles then broke big-time
There are 10 types of people in this world;
Those that understand binary,
and those that don't.
Post #577900 31st Dec 2020 4:31pm
Ricardo Villa
W, thanks for tip and diagram, very helpful. Will give it a go on a warm day, whenever that will be 🌞 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Post #577901 31st Dec 2020 4:34pm
Laurie915
Australia 2010 Range Rover Autobiography TDV8 Buckingham Blue
A carefully used hairdryer, with a cloth to protect paint etc should get you out of trouble !
Laurie
Post #577947 31st Dec 2020 11:55pm
DrRob
I’ll try that myself as mine has a little lift on the seal too
Bow down Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #577959 1st Jan 2021 9:15am
Ricardo Villa
Yes definitely worth a go. Probably will add bit of sealant too to help ! I've used a mouldable glue called Sugru before to seal things, is very handy stuff. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Post #577966 1st Jan 2021 11:42am
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
Anyone had any luck sorting this seal? Just noticed mine is exactly the same as Ricardo’s. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #598417 22nd Jun 2021 8:14pm
Ricardo Villa
Been lazy so Actually haven't done mine yet! Got some sugru so will have a go and advise how it goes. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Post #598427 22nd Jun 2021 10:30pm
