Home > Technical (L322) > How rusty is your subframe ?
mazza7282
United Kingdom 2003 Range Rover SE Td6 Adriatic Blue
Yet another rust post Laughing . Struggling to keep up with all of it.
Just greased up the transmission selector rod and thought id take a look at a small hole in the subframe/engine. cradle that I noticed a few months back.
Pocking around in it a little bit and getting the vaccum out, what was a small hole is now a bigger hole.
Ill get this welded up when it has its 1/2 shaft sepated from the hub due to siezure (another post).
Its not good, but at least the debris is out and the remaining metal around the hole is structurely sound.
That said the rest of the subframe is erm ......... lets just say ill ne doing this for some time Bow down hoping and praying.
Ive prodded and poked around the rest and it appears ok (laying flat on my back on the driveway), maybe a few things lurking that would be noticed on a ramp.
I mean is this normal for these ?? - As you can see my jack stands have started to deform the other side of the metal (hence showing additional signs of subframe softness).
So i’ve had to find another area of good quality to lower the car on whilst leaving the 3 ton trolley jack in place for added safety.
As you can see-ive had a previous section welded & painted for its last MOT
Post #577390 27th Dec 2020 4:49pm
p38arover
Australia
My 2003 L322 subframe looks almost new - there’s no sign of rust anywhere underneath (nor elsewhere). No salt on roads down here Smile Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #577432 27th Dec 2020 9:48pm
dhallworth
How easy is it to replace a subframe? Would it be feasible to source one from a breaker, make sure it’s spot on and coated properly and then fit it to the car rather then chasing rust on your back underneath it? 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #577438 27th Dec 2020 10:34pm
mazza7282
Welcome to UK motoring Laughing Laughing
Post #577439 27th Dec 2020 11:18pm
mazza7282
The ones ive seen on ebay dont look too far off and there at £200+ Sad
The labour alone would be astranomical to get someone else to replace it, and as you mention before. I’ll be flat on my back trying to swap it out. Like most thing, would be easier with a 2 post 3 ton + ramp.
The car is almost at 200.000 miles - I dont really think it would be worth the expense swapping it, as im in it for quite a bit since I bought it now, on items that im not set out to do such as
-Paint
-Welding
-In more recent post, press tools for bush and 1/2 shaft removal due to siezure. + bolts that have snapped off due me trying to remove the wheel knuckle (goes into the workshop week after next for that)
Post #577440 27th Dec 2020 11:26pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
I think it depends on what commitment you have made into the car...
If I had to replace the subframe on mine, it would be a no brainer I would just get on with it, its not a highly skilled job, just a huge amount of work.
There are two areas I would question and that is how to support the car and also how to support the engine as that rests on the subframe.
Once you have solved those then just disconnect everything (eg electrics, hydraulics and drive shafts) and drop the subframe with all the suspension components and slide them out.
Rebuild the whole subframe with new bushes all round and slide it back in.
As I said a lot of work (yes I have done it before but not on anything any way near this big) but not requiring great skill, maybe lots of guts and determination or just being plain Censored stubborn.
For me I reckon a couple of weeks would do it, but somebody who is fit may a weekend or two. Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #577444 28th Dec 2020 2:20am
FrankN
Germany 2004 Range Rover Vogue Td6 Bonatti Grey
I have make it , its a lot of work , at first you need a good subframe , we have sandblasting and painting it with a good fat colour at last as eyecatcher a new colour in the car grey Very Happy and at the last a painting inside and outside with wax
and than you must the exhauster from the heater on this place, this ist the problem , original hot air directly comes on the subframe and inside water , so comes the rust inside
the big desaster was the drive shaft to dismantling , the rest is easy, good luck
regards
Frank
This is the side from the heather
Post #577469 28th Dec 2020 11:17am
Look doable, but a pretty chunky heavy job.
As you sat I reckon not too hard on a lift, so unless you are set on swapping it your self then I would get a garage to price it up, it may be less than you think labour only. There is nothing that can't be fixed with a hammer😜😜
Post #577491 28th Dec 2020 2:16pm
Danwilderspin
I had a 2002 4.4 completely rotten rear subframe (check this too!!!) but it had had a very slow oil leak from prior to my ownership and despite changing rocker covers and the pcv still dropped it Kepler the ground subframe soaked I cleaned it up and it looked like new still Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #577651 29th Dec 2020 12:36pm
^^ Sprayed both the subframes with oil every year since I got the car. The original paint is still on them. Thumbs Up
Post #577655 29th Dec 2020 1:00pm
mazza7282
"FrankN"
Looking back at the before and after photo's, wow !!! that subframe had quite the crack !!.Plus with use of a decent ramp, made it all the more easy to navigate rather than laying flat on your back.
I see the vehicle on the ramp is being supported by the official jacking points, I tell you...my trolley jack went straight through the rear ones before I got new sills put in and had the jack points at the rear re-enforced)
Is that your ramp in a garage or at a car garage ?
My garage doesn't trust it, so so it goes on there MOT ramp instead. I too always lift it on the chassis from them on, even though the jack points structure at the rear are brand new.
"bigbo and northernmonkeyjones"
It is definitely something I would undertake as I have removed engine/subframes from nn Astra and a E46 325ci on the driveway, but they are much lighter in comparison to this 3 tonne beast !
.................Going slightly off topic............................
The plan originally was to purchase the car (£1000) put a £1000 into it i.e welding, paint, materials and to sort out the interment running issue, then to see where I went from there. The car was always purchased as a project, and not a daily
But as its taken up quite a bit of my time (And the welding and paintwork went over ££) I may as well keep it now, plus it does drive better (when it works) than my WJ 4.7 V8 Grand Cherokee that I have just sold which I owned for 10 years. I used the Grand Cherokee originally to pick this vehicle up as it wouldn't stay running.
Honestly i'm probably into the far for the following: -
-New rear wheel arches , inner & outer sills + arches off a 2010 range rover
+ the welding (garage)
-inner and outer sills at the back
-paintwork after welding (garage)
^^^ The most expensive bit ^^^^^
-whole car machine machine polish
-paint seal
-4x brake pads (All 4 were originally at flat as freshly laid tarmac)
-coolant change
-oil change
-air filter change
-diesel filter change
-low pressure sensor on top diesel filter (twice)
-in tank lift pump (bosch) with level sensors
-in line fuel pump (bosch)
-new battery
-diff oil front
-diff oil rear
-specially developed transfer case oil (castrol FMB BOT 21 i think)
-gearbox oil overnight drain (7 litres with lucas stop slip)
-external gear selector rod lube up each month to help it go into gear when cold
-new high level brake light
-new towing electric plug as it stopped working
-replacement steering wheel (as it was Censored and worn)
-replacement lower steering shaft (as it was wandering)
-new lower control arms and lower ball joints (FOR MOT)
-new sway bar drop links
Upcoming work
-new inner and outer cv gator at nearside rear, once 1/2 shaft is separated from the hub (garage as I can't separate it, you have probably seen on another thread)
All that aside on a good day I think it looks smashing !
But this subframe (Now compared to the rest of it, really needs attention)
Post #577685 29th Dec 2020 5:22pm
mazza7282
If mine was in great nic, I would be doing the same Very Happy
Post #577687 29th Dec 2020 5:23pm
FrankN
@ mazza
The car have I repaired by a friend , on my ramp is standing my Jag with a charger defekt .
For all , oil outside is good but inside is the rust beginning , I have closed the draining and put anti rust inside for 12 hours but you must rotate it of all sides
, than I have make wax inside , I think it’s life longer as the car is running
Regards and a happy new year tomorrow
Frank
Post #577847 31st Dec 2020 9:47am
^^ if you can seal all the holes in the subframe why not just fill it with oil? That would provide 100% corrosion resistance.
Post #577857 31st Dec 2020 10:42am
FrankN
Is the subframe is new , but when you many years later begins with him the rust is inside , I don’t know what is the best ,
Regards
Frank
Post #577858 31st Dec 2020 10:51am
