Home > Technical (L322) > Key syncing and remote locking
Ianb4310
First of all merry Christmas to everyone 🎄
I have had a flip key made by pixels fixed obviously through the post I sent my spare off!
When I’ve come to sync the new key it will not turn in the ignition but it will turn in the door lock?
I’ve used hold unlock and press lock 3 times method.
Because the new key would not turn in the ignition I used my primary key to turn in ignition then remove it and hold lock and unlock etc, now when I put the new key near the ignition I can hear a click but it still will not turn or lock/unlock the car??
Now my primary key will start the car but will not lock/unlock the car remotely??
Any ideas please?? have I done something wrong and deleted my primary key?
Thanks
Post #577155 25th Dec 2020 10:32am
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
I can't say for sure but I had a similar issue myself recently.
I believe that to sync so you can remotely lock/unlock you need to be able to turn the key in the ignition. I think that process tells the system that one particular key is about to be sync'd.
If the second key won't rotate in the ignition then I think you would need to resolve that issue first.
What I don't know is, if the key has not been configured for your car yet (linking the key to the security system with the Land Rover diagnostics or with some aftermarket one), will you be able to even rotate it in the door or ignition?
Good luck!
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #577174 25th Dec 2020 3:41pm
Weegie
You need to indicate what car you have, John
GAP iiD BT
Post #577177 25th Dec 2020 6:03pm
Ianb4310
Sorry 2006 L322 td6
Post #577178 25th Dec 2020 6:25pm
Ianb4310
Can anyone program keys near Gainsborough/Lincoln Scunthorpe area I can’t get any of my keys to lock/unlock remotely
Thanks
Post #577227 26th Dec 2020 1:40pm
Ianb4310
Help please!!
I can’t get any of my keys to turn in the ignition now there is a clicking sound when the keys go near the barrel but that’s it
Post #577333 27th Dec 2020 12:50pm
Ianb4310
Panic over got original key working buy disconnecting battery and touching terminal together then re sync
But still can’t get aftermarket key to even turn in ignition but it will turn door lock??
Post #577340 27th Dec 2020 1:32pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Reads to me like your new key hasn’t been coded to your vehicle. Without that it just won’t work. Where did that key come from? Why didn’t they code it for you?
I’ve got tools to do it, it sadly you are too far away. But any car locksmith should be able to code it to the vehicle.
Post #577380 27th Dec 2020 4:48pm
Ianb4310
I got it from pixels fixed who I’ve used before on my BMW X5!
I posted my spare to him as I wanted a flip style key and he sent me a new flip key with the blade cut he said it should just need syncing??
I’ve got the procedure but the new key will not turn in the ignition?? to start the syncing process
Post #577382 27th Dec 2020 4:52pm
Bl4ckD0g
I would go back to pixels fixed. However if they don’t have had your car then I am miffed as to how the new key is supposed to be coded to it????
If the key is not coded to the ignition then it won’t do anything. There is a transponder in it that will communicated with the car.
This is not the same as synchronising remote control buttons to work. Not simply cutting a blade.
Post #577391 27th Dec 2020 5:50pm
Bl4ckD0g
My order of events for a new key.
1. Buy key electronics and blank blade
2. Copy the blade from an existing key.
3. Code the transponder to the car.
4. Synchronise the remote control buttons.
It reads to me that 3 isn’t done on your car key.
Post #577392 27th Dec 2020 5:53pm
Ianb4310
Thanks I’ll contact him and see what he says
Post #577393 27th Dec 2020 6:01pm
