Home > Technical (L322) > Unable to remove driveshaft from rear wheel hub :( |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
For £150, I'll let them have the hassle |
22nd Dec 2020 9:05pm |
mazza7282 Member Since: 10 May 2020 Location: Essex Posts: 99 |
lol I thought as much, its one of those “just because you can, doesnt mean you should”
22nd Dec 2020 11:03pm |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 |
https://www.ebay.co.uk/itm/10T-Hydraulic-P...SwvEFfcvI~
23rd Dec 2020 12:57am |
forgot to mention that if its tight enough that you need a tool to get it apart you will also probly need one to put it back together!
23rd Dec 2020 1:09am |
Im not continuing with it anymore mate
23rd Dec 2020 10:01am |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 558 |
Just to close my promise of pictures of the hub puller a friend and I made...
31st Dec 2020 1:16am |
Looks good - very manly lol Current Fleet
31st Dec 2020 9:34am |
We’ll the knuckle assembly & shaft is out, but not separated (still !)
5th Jan 2021 7:39pm |
I have been asked for some dimensions so hope this helps
10th Jan 2021 3:54pm |
Bloomin marvelous
10th Jan 2021 4:13pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16248 |
So would have been far easier and cheaper to have bought the correct tool in the first place then sir? 👍 |
10th Jan 2021 8:46pm |
well duuuh !!!! Current Fleet
11th Jan 2021 8:21am |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 |
I wish I had that a year ago when I replaced all four shafts with new reluctor rings , a pig of a job which I did with a large heavy duty tube and a sledge hammer now I can see a driveshaft boot needing replaced . Do you know if someone has been making this version of puller or is down to taking these measurements and giving it to an engineering shop. I think I could do the reverse refitting tool. |
11th Jan 2021 3:30pm |
I believe bigbo and a few others have been making their own pullers with assistance from freinds/engineering shops I’m very greatful for this and my hopefully my mate is also making me up something similar too. Maybe ill tackle the rear again in the summer, or I will wait until those brake shoe pins rust through
11th Jan 2021 9:21pm |
