Home > Photos, Videos & Media > Sad accident
1JBS
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
Sad accident
Spotted in the paper today -
https://www.dailymail.co.uk/news/article-9...ector.html
Post #576972 22nd Dec 2020 1:45pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Yeah I looked at this, seems to me that she put the car in to reverse and left the engine running. If it had just rolled as stated then it would have stopped once it initially hit the lady. I'm sure LR will have to carry out a full inspection of the vehicle for faults so in the meantime it's just speculation for us observers. Either way it's a sad outcome for the family 2011 TDV8 Vogue SE
Post #576977 22nd Dec 2020 2:05pm
Martin2
Sad outcome, but you can't blame the car, it's clearly driver error. MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #576987 22nd Dec 2020 3:18pm
Pretty sure it automatically should select park if you turn it off..... There is nothing that can't be fixed with a hammer😜😜
Post #576993 22nd Dec 2020 3:35pm
I feel the need for some testing.
Mine certainly goes doom Drive (or Sport) into Park if I turn it off - that's my normal routine, I rarely select Park myself. Not sure what happens if it's in Neutral and you switch off though.
As above though, I'm not sure it's a failure of the car - unless it's jumping out of Park somehow.
Post #576994 22nd Dec 2020 3:46pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
Really sad for the family.
i dont know if the clip was sped up but it does seem to be moving quick mine does not crawl that quick?
also regardless of where the dial is mine just sorts it self when i kill the engine. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #577007 22nd Dec 2020 5:44pm
GraemeS
The L322 owners manual states that if in neutral when switched off then park will be selected after 10 minutes. The gearbox has to be in gear to immediately select park.
Post #577018 22nd Dec 2020 7:25pm
chawks
United Kingdom 2002 Range Rover HSE 4.4 V8 Alveston Red
Is it not easy to see which gear it is in from looking at the illuminated display just in front of the dial?
Post #577032 22nd Dec 2020 8:46pm
That's horrific!
Is it normal to exit a car in the states leaving it running? If so, that maybe needs to be addressed no?
Post #577139 25th Dec 2020 12:22am
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
As she had 2 children she doesn't qualify for a Darwin Award but she should get an honourable mention.
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #577141 25th Dec 2020 12:28am
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Drivers confused? Well fair enough. So if it confuses you, then surely you make sure you put the hand brake on Wink
Sad it ended like this, but come on, some people really shouldn't be driving...
Post #577153 25th Dec 2020 8:18am
TeeMyob
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Shocking Story. Terrible for the family. Just when you think your having a bad day.
Without causing death, but came pretty close.
20 Years ago, I had an S-Class Mercedes that had been in for repair. It Careered across the car park (not in my usual spot - otherwise it would have been onto a busy road). My 11 year old daughter was in the car.
Mercedes Garage had not carried out repairs correctly after replacing the gearbox.
Had I known what I know now, I would have sued the pants off emm. They had the car more than I did for repairs prior to that.
Post #579282 11th Jan 2021 11:06am
