Home > Maintenance & Mods (L322) > What to do if your DPF is blocked... |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 330 |
Also the EGR is a 9 hour job so pipes first.
31st Oct 2020 9:49pm |
RRD Member Since: 19 Mar 2014 Location: Antwerp Posts: 40 |
I had my mechanic do a high pressure leak test and no leaks were found...
4th Nov 2020 4:34pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3185 |
I very much doubt your DPF is full. Get them to do a Pressure test. If it is getting full it will read c. 15PSI. Mine was reading 25g of soot and raised a yellow light (DPF full) but the pressure was less than 2PSI!!
4th Nov 2020 7:07pm |
AdamCzix Member Since: 02 Dec 2020 Location: Luton Posts: 13 |
Hi Guys,
21st Dec 2020 12:26pm |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 |
Hi Adam, I have been down the path you appear to be on at the moment and the first thing I would advise is to get a high pressure smoke test carried out to see if there are any leaks on the intake side. From what you describe it sounds more like a leak than an electrical issue. 2011 TDV8 Vogue SE |
21st Dec 2020 12:56pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 |
Hi Adam,
21st Dec 2020 1:11pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4310 |
High pressure smoke test as a priority to rule out an intake leak - 4 hoses, intake manifolds etc. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
21st Dec 2020 1:12pm |
I'm also seeing a possible alternator issue there mate
21st Dec 2020 1:13pm |
Thanks for reply guys. Yes, all the sensors cleaned yesterday so no problem there.
21st Dec 2020 1:31pm |
21st Dec 2020 2:12pm |
The throttle body to intercooler hose is generally a poor fit, I have recently put a brand new one and although it did seat better, you can still move it more than I would have expected. The big problem there is that you cannot buy just the seal 2011 TDV8 Vogue SE |
21st Dec 2020 2:27pm |
Mine was leaking exactly there.
21st Dec 2020 8:11pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1255 |
On the part you are pointing at should have a double lipped green seal inside. The hose will move back and forth a bit but certainly shouldn't rattle from side to side. |
21st Dec 2020 9:57pm |
Firstly, all the advice above is good. It is particularly excellent that you recognised your indy was talking nonsense when he said:
21st Dec 2020 11:49pm |
