![]() | Home > Technical (L405) > Idle speed going up and down then cutting out |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
I think the first question has to be, why was the DPF removed? 2011 TDV8 Vogue SE |
Dirty MAF? Fuel pump blockage? Injectors? |
Tim.C Member Since: 27 Jun 2020 Location: Halesowen Posts: 4 ![]() ![]() |
He did say that the place he took it that don't seem to be able to fix it: "the guy cleaned a something which had carbon on it and still doesn’t get fixed"
I thought that - I will ask. I know he hasn't had it that long, so could have been a previous owner....... |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Can you ask your friend if the 4 x 4 screen comes on once it stalls ? Of so it a known fault and a cheap and easy fix.
His reply was;
Intelligent is a stretch, more experience I think |
