Home > Maintenance & Mods (L322) > Belt noise when cold |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4301 |
Needed belt, guides, bearings and tensioner doing to get rid of squeaks on mine Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
20th Dec 2020 8:58pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1205 |
Hi Steve. My car is the same age as yours and mines being doing it for the last 6 months. For peace of mind just make sure the belt is fully on the full width of the pulleys. If that's the case don't worry. Other members have reported the belt not being fully on the pulleys and that's the time to get it sorted pronto. |
20th Dec 2020 8:59pm |
Blitzsah Member Since: 13 Dec 2020 Location: Warwickshire Posts: 23 |
Thanks both for the quick responses. I will make sure the belt is correctly seated on the pulleys. Access is not too good though to get to it, will try my best! |
20th Dec 2020 10:12pm |
Mike220 Member Since: 21 Sep 2020 Location: uk Posts: 116 |
Must be the cold weather as my 2011 tdv8 is just the same, only lasts a few minutes but it's now on the list to sort. Definitely a pulley or guide somewhere, need to do a bit of investigation to determine which one (before jumping in and replacing the lot).
20th Dec 2020 10:14pm |
Hi Rob, did you use genuine or pattern parts? |
20th Dec 2020 10:43pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8503 |
Mine did it, got some manol belt cleaner and gave it a squirt, stopped it for a bit.
20th Dec 2020 10:45pm |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
Mine does it a bit as well in the cold weather. Besides the embarrassment, I wouldn't worry about it too much. I had my water pump sorted etc, I just put it down in the garage having set it up too tight. |
21st Dec 2020 6:50am |
All Genuine. Rovertune did it all when it was in for its new secondary turbo. I also got them to change the top coolant hose as it was removed to do the tensioners etc. Preventative maintenance Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
21st Dec 2020 8:13am |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 683 |
Top Tip!
21st Dec 2020 8:22am |
MattC Member Since: 27 Oct 2016 Location: Surrey Posts: 25 |
Get the alternator belt changed (and pulleys) as quickly as possible!
21st Dec 2020 8:49am |
Gonna go for genuine me thinks. Just done my top hose because it was leaking. Thanks. |
21st Dec 2020 12:09pm |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 |
can also be caused by low power steering fluid! |
21st Dec 2020 3:59pm |
QuebecTango Member Since: 06 Jan 2019 Location: Brighton Posts: 55 |
Had this symptom on my 2011 Tdv8, there is a modified bracket to mount the alternator which is the official fix, had this done about 18 months ago with new tensioner & pulleys and of course both belts. Replaced the alternator as a precaution whilst it was apart with a Denso unit from advanced factors. 10,000 miles on and all still good. |
21st Dec 2020 5:35pm |
Have you got a part number for the modified bracket? |
21st Dec 2020 7:08pm |
