Home > Technical (L322) > iid tool to turn towing on
Landmark
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
Hi all can anyone advise procedure to turn on towing facility using Gap IID tool. just fitted towbar to l322 year 2009 but is classed as 2010-2012 ie has digital dash and Jaguar looms as opposed to BMW. iwas told by tow bar supplier i would need to activate tow ecu using diagnostic tool. Regards Mark
Post #576594 19th Dec 2020 2:05pm
its under BCM-body control menu... ... - .- -.
Post #576597 19th Dec 2020 3:30pm
Landmark
Hi Stan thanks for your promt reply, found it. i wasn't to sure which bits to turn on so turned on individually. Tow ball yes tow stability yes and tow 13pin fitted. On uploading it went through its functions and then said upload failed, i then hit continue and it said 100% complete. I went back in and all are activated. Also had persistant fault code b1311-96 (2f) any ideas??? sais clock module component failure-internal fail. Is is it refering to actual clock ie time because no problems.
Post #576602 19th Dec 2020 3:52pm
Rodjules
United Kingdom 2015 Range Rover Vogue SE SDV8 Causeway Grey
I have that exact same clock fault message on my 2012 Westie and it won't clear with the GAP tool. On the positive although
i have absolutely no idea what its referring to it seem to have no impact as everything appears to be working normally !!! 2015 L405 Range Rover 4.4Sdv8 Vogue SE, Baltic Blue, Ivory
2012 L322 Range Rover 4.4 Westminster Baltic Blue, Ivory - Deceased
2012 Discovery 4 HSE 3.0 Sdv6 Oslo Grey, Black - Gone
2006 L322 Range Rover Td6 Vogue SE Buckingham Blue, Parchment - Gone
1996 P38 Range Rover 4.6 HSE Rioja Red, Black - Gone
1990 Landrover 110 2.5TD CSW - Why Oh Why ???
Post #576981 22nd Dec 2020 2:28pm
