Home > My Range Rover > New RR now picked Up
mjdronfield
Sounds like it’s best to get it checked then. Mines mostly left in the auto fan and auto distribution setting. Don’t very often select face vents, think mine work 🤣
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #576533 18th Dec 2020 3:14pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
Hi glad your enjoying the car.
1) reverse camera on my 2012 stays on until i move forward or a min or so has elapsed
2) if you turn your fan on full or select defrost you should really hear the fan blowing hard it is quite noisy
3) Heat my car (I leave in auto) does not start really blowing hot air until the care is at temp, so in cold weather it can take a little while for hot air to come through.
hope this helps 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #576551 18th Dec 2020 5:53pm
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
Also, the vent in the centre of the dash has a slider which goes from cold to hot - it will always be cold if it's on the cold setting, regardless of the climate settings.
Obviously, the lights have to be on, on the relevant vent controls in order for them to be open too.
I don't think the fan on full is particularly loud compared to other cars - I've only had the car a few months I presumed this is by design, it does get the car warm quickly, just in a subtle manner Smile
(obvious things perhaps, but some people miss these things!)
Post #576554 18th Dec 2020 6:14pm
Ricardo Villa
United Kingdom 2009 Range Rover Vogue TDV8 Bournville
Thanks, just seems a little feeble on the heating front, will check that centre vent to see how it's set. Yes on my rear camera it stays on for. A few seconds when selecting D but then goes off.. going in after Christmas to get it all checked out. Will let you know outcome.
Had funny issue yesterday when starting up for first time, nothing happened when pressing starter button, kept saying put foot on brake which I had pressed? Pressed and released couple of times and it started. Never happened again all day. Does this operate off brake light switch or something else, anyone else had this ? 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
2005 Jaguar XJ350 3.0 V6 Sovereign, Jaguar Racing Green, Ivory
1997 TVR Chimaera 450, Formula Red, Grey
Post #576628 19th Dec 2020 7:00pm
lostinespace
United Kingdom 2009 Range Rover Vogue SE TDV8 Zambezi Silver
Mine seems to do the same, I just keep pressing the brake and button eventually it goes. For those 20 seconds I am watching my wallet get emptied in my head. 2009 TDV8 3.6
Post #576629 19th Dec 2020 7:09pm
mjdronfield
Been out in mine today. Never really noticed, but rear camera stayed on for a few seconds after selecting D....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #576632 19th Dec 2020 7:30pm
Ricardo Villa
Sounds like it's not unique but I guess few things are on these! Hope it's just an occasional occurrence. Maybe the A/c is as good as it gets but will see what garage says. My Jag one has never been touched but is still icy cold and hot when it's requested. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Post #576636 19th Dec 2020 8:17pm
Also clean out the little vent in the heating control panel. Behind it is the temperature sensor and there is a little fan which blows over it.
If you get a compressed air spray and give it a blast it will knock all the crud off it and it can read the internal temps properly then. There is nothing that can't be fixed with a hammer😜😜
Post #576657 20th Dec 2020 8:29am
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Ricardo Villa wrote:
Thanks guys, for some reason leaving doors open does run battery down, it does on my Jag too. Yes I'm a fan of light interiors and a bit of wood, some say old fashioned but I say class!🤣 Been cleaning leather and treating couple of scuffs with Furniture Clinic product, managed to mix a good match from kit I had for Jaguar, Ivory with bit of yellow seems very close.
Loving the car so far, couple of questions:-
Climate control doesn't seem particularly hot on max or cold on min, is something amiss?
Noticed when selecting reverse, rear camera comes on but doesn't always go off when selecting another gear unless you cancel it?
Also in top left a triangle with exclamation mark appears, presume this is a warning?
Any info on these?
Regards
It is a climate control system that I've experienced on no other car, I still find it annoying. But for whatever strange British engineering concept it isn't just controlled by the climate control controls, the horizontal rotator below the central vents seems to do the actual job of the settings. Well on mine it does, perhaps your is the same.
Generally keeping it in the middle of blue/red seems to work, but if it is more towards the red it goes much warmer, and if it is in the blue zone the aircon seems to kick in.
A very odd user interface in my opinion. But at least I now no longer feel like I have to take the system apart and can confirm my aircon and heater exchange work just fine.
But in my opinion, whoever thought of those controls should be sacked and shot Wink
Post #576663 20th Dec 2020 9:17am
mjdronfield
The control under the central vent controls the vent temperature relative to the main control settings, so you can have the vents a bit warmer or cooler than the rest of the system. Some folk like cooler air to face but warmer feet.
I think it works well.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #576685 20th Dec 2020 12:21pm
Bl4ckD0g
Maybe mine is broken as it affects all air temperature dramatically.
Post #576688 20th Dec 2020 1:03pm
Siftah
You mean it affects the temp from *other* vents too?
I'd not noticed that on mine, pretty sure it only affects that one vent but I'll check next time I'm out! I think the idea is that it lets you have a cooler vent whilst keeping the car at a set temp.
The air-con is pretty much always on by default, with the idea that it cools and *dries* the air first, then re-heats it to the temperature you set. That's pretty common in cars AFAIK, as it helps to control moisture in the cabin, keeps the windows demisted etc, especially relevant if you jump in the car with wet gear from skiing or have a dog that likes splashing in puddles and things. Smile
Post #576710 20th Dec 2020 4:11pm
Ricardo Villa
Seems to be a few things that can affect how it heats/cools. Will check temp sensor and try and give it a blow through. Central vent was sent on cold, have moved it to the red sector and will see tomorrow if it changes anything. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Post #576719 20th Dec 2020 4:47pm
