![]() | Home > Technical (L322) > Help! Starting problem - gear lever?? |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 869 ![]() ![]() ![]() |
Had a couple of times where my car wouldn't start/ wouldn't even turn over. I'm going to Devon on holiday in it on Monday so need to sort it sharpish.
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2050 ![]() ![]() |
Have you tried Jump leads / Booster pack when it happens?
Did you get the clicking under the gear lever?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35490 ![]() ![]() |
hoppy, i'm sure i read somewhere that theres something under the gear stick console that gets stuck or fails... ... - .- -.
That sounds like my problem stan, I can't find it on here though?
i tried a search as well ,couldnt find it either ,hopefully someone with memory of this will advise.. ... - .- -.
found this but its not exactly like your problem but it might help...
Just been and had it apart again. I thought it might have been the brass looking motor type thingy, but I think that's the locking mechanism that keeps it in park till you press the brake. I couldn't get it to replicate the fault (typical) so will have to wait till it goes again before I can look closer.
lets hope its a one off LEE.. |
I'm not that lucky! Plus, it's a 3 off already |
