Home > Maintenance & Mods (L322) > Handbrake shoe pins
Danwilderspin
Handbrake shoe pins
Hi all after such a horrendous noise from the rear while driving a stripped the brakes and found the pins were rattling around. The backing plate it goes into has rotten - is it a new backing plate job or is there a better way? What's the damage for a plate normally...
Post #400420 13th Aug 2016 9:33pm
Ivor
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
someone on here put some washers and metal putty behind irrc L322 2008 vogue
R53 Cooper S Works tuned beyond the works SOLD
R33 Nissan Skyline in rebuild 400bhp atw
Post #400435 13th Aug 2016 11:09pm
Roystonh
Here's a nice shoe pin for you Rolling with laughter
 2005 L322 Vogue Gold gone
2006 L322 Vogue Black gone
2011 L322 Vogue Silver gone
2011 L322 Autobiography Black gone
2015 L405 Autobiography LWB Black gone
2019 L405 P400e Range Rover Autobiography LWB Eiger grey / black roof gone
2001 P38a 30th Anniversary Wimbledon Green gone
2019 L405 P525 Autobiography LWB British Racing Green
Post #400444 14th Aug 2016 12:00am
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
I know a common fix is little nuts, bolts and washers but they obviously have a time limit! Won't be long and you will have to replace again!
I had the same problem when I bought my car but the back shields came with the car. Rather than split the hub etc as it is a pretty big job to change, I got my father to cut them in half and make a little strap!
All I had to do was paint them, and cut down the small screw once fitted so it was clear of the brake disc!
Here is a picture... They were easy to fit just cleaned up the area with a wire brush and bolted them together top and bottom, and once the three bolts were in they are solid.
He got the idea from an American company that apparently you can buy them like this but with welded straps!
Post #400456 14th Aug 2016 8:24am
very handy tip steven.. Thumbs Up ... - .- -.
Post #400461 14th Aug 2016 8:50am
andygts
my old FF had the same problem.
Simple fix, costs only a few quid and is as good as factory.
mk3 ford fiesta brake shoe fitting kit. They use slightly longer pins but also come with a seprate button to hold them instead of locking into the backing plate Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #400481 14th Aug 2016 12:16pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
To revive an old thread.
We have just had our rear handbrake shoes replaced on our 2003 L322. The pins had rotted and the shoes were grinding on the drums on the nearside.
I had printed off the images of cutting the backplates from this thread which is what he did, fitted the new brakes, drums, backplates etc (all OEM parts) and rewelded the backplates and has done a great job.
Saved all the grief (and expense) of removing the hub and driveshafts and the job was done in a day!
He now just has to replaced the handbrake cable!
Stan, would this thread be worth putting in the Wiki as a work-around for replacing the backplates, because it works!!
Post #563534 4th Aug 2020 11:30am
Danwilderspin
On my old one I bought a kit with different pins and washers from a Citroen I believe which bought me lots of life Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #563570 4th Aug 2020 4:43pm
mazza7282
United Kingdom 2003 Range Rover SE Td6 Adriatic Blue
Don't suppose anyone has any part numbers for these Fiesta/Citroen brake shoe fitting kits do you ? Smile
Rung up my local motor factors but as they didnt have a reg, they coudlnt find anything :p
At present - im just googling old fiestas and typing the reg into euri car parts lol
Post #576427 17th Dec 2020 11:21am
drakes
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
When I looked I found them on Ebay 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
2005 4.4V8 (M62) Bonatti Grey/ Parchment interior - gone
1998 4.6HSE Blue/ Cream interior (can't remember exact colours) - gone
1977 White - gone (should have kept)
Post #576452 17th Dec 2020 4:54pm
andygts
From memory I think this is what I used but it's going back a fair few years now.
https://www.ebay.co.uk/itm/BRAKE-SHOE-HOLD...890.l49292 Current
Previous
Post #576454 17th Dec 2020 5:11pm
mazza7282
Thanks
Yes I saw some on ebay too but my parts shop couldnt cross ref a euro car parts number.
In the end what they let me do is look at all there fitting kits in there stores to shut me up.’
I was able to find a suitable solution Smile
However ive had a nightmare getting this rear disc over the brake shoes, the adjuster is wound all the way in and ive wiggled them around but I just cant get the disc over the shoes.
so currently ive just ledt it with no handbrake shoes on the left hand side until I figure it out.
Its dark n cold outside now so ill re-tackle this again
Post #576470 17th Dec 2020 8:05pm
