Home > Technical (L322) > Headlining out - any other checks before refit?? tips please |
gravitylover Member Since: 08 Nov 2020 Location: Southeast NY Posts: 36 |
I had some seriously blocked up drain hoses, it took a fair bit of compressed air blown through in bursts to unclog them. I think my sunroof drain tray is cracked but the guy I got it from said he glued it sufficiently that it's draining right now. I'm also curious about the shark fin leaking since my headliner has sagged off the base in the rear. I would sure love to see some pictures of the inside of the roof with the liner out if you could. |
13th Dec 2020 8:14pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
DONT blow through the drains with compressed air unless it’s 2010 plus!
14th Dec 2020 11:51pm |
It seems to have worked pretty well. He blew from the bottom up not top down if that makes a difference. Either way, when it's raining there's water pouring out the hose so for now I'll call it good but that's part of why I want to see what it looks like with the headliner out. |
14th Dec 2020 11:55pm |
you may have got lucky or they may have used their brains and put cable ties on from the get go on the NAS spec models... Current stable:
15th Dec 2020 9:16am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8192 |
Check the windscreen for leaks, they can come unstuck and leak badly, a hose on the top and sides and you can see it up under the foot wells if it leaks, especially if it’s not the original screen... Pete
15th Dec 2020 11:33am |
andyt109 Member Since: 23 Nov 2020 Location: London Posts: 29 |
Hi Everyone,
24th Dec 2020 1:09am |
Here are some pics of the tray down and being sealed. There is a cross hose at the back, this may need unblocking and cable tie treatment too.
24th Dec 2020 1:16am |
Good stuff, thanks. I need to get in there and do this too. My drain tray had a crack in it that is supposedly fixed but I want to solve whatever is going on for good. Hey you didn't happen to take any pics of the roof with the headliner down did you? My rear window washer doesn't work and I'm curious where the line runs. |
24th Dec 2020 9:12pm |
So apart from that video i can't see where the line runs clearly, I had a look at my photos. Did you locate it? |
4th Jan 2021 12:06pm |
I haven't dropped the headliner yet. I get pretty wimpy when it comes to working on my cars outside in the winter so until we get a warm day most things are on hold. I really need a garage... |
4th Jan 2021 12:24pm |
