Home > General > Laughable Question About Sport Mode.. |
Classic Matt Member Since: 05 Sep 2020 Location: West Sussex Posts: 72 |
I am fully prepared to be laughed at for asking this but...
13th Dec 2020 10:30am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16305 |
Placing the 4.4 into sport mode is more like a supersport mode on these models... You'll find the car holds gears way up into the rev range and turns the whole car angry! I believe this is why they put the extra step into engaging sport mode, sir... So it's not done accidentally? |
13th Dec 2020 11:29am |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
does it really make that much difference?
13th Dec 2020 12:11pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8671 |
Holds gears longer.
13th Dec 2020 12:22pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
+1 with Craig on "angry"
13th Dec 2020 12:24pm |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
I have no facts for it; but on my 5.0SC sports mode also seems to alter throttle response. At least it feels like it as the throttle barely needs touching compared to non sport. The dampers are dynamic anyway And I also have a button to open the valves of the exhaust for a straight pipe 😎
13th Dec 2020 1:03pm |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 347 |
The problem I find when using the flappy paddles in "D" is that as it wants to change up at such a low RPM, you find that telling it to change down is mostly pointless, as the gearbox changes back up almost immediately.
13th Dec 2020 1:09pm |
Okay great thanks all. I will give flicking into S a go tomorrow.
13th Dec 2020 1:21pm |
Only Time I ever use S is when towing to get the car to hold a higher gear than it wants to in D. I agree that in S it does hold the manual selection properly, but tbh I don’t find myself driving in a way which requires much in the way of holding a lower gear.
13th Dec 2020 2:12pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4310 |
S holds it in gear longer. I use it on slip roads to get above 2500rpm to regulary clear second turbo pipelines Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
13th Dec 2020 3:32pm |
"Just clearing the second turbo pipelines officer, honest"
13th Dec 2020 5:18pm |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 461 |
Happy to be corrected but I thought sport mode also stiffened the dampers, mine feels tighter when driven spirited on bendy roads when in sport mode. |
13th Dec 2020 10:22pm |
Nope. Does nothing to the dampers. It feels tighter when you drive in a spirited manner, because they are adaptive, they tighten up when you give it some... There is nothing that can't be fixed with a hammer😜😜
13th Dec 2020 10:27pm |
The more you give it, the tighter it becomes! OOH ERR MISSUS! |
13th Dec 2020 11:10pm |
