Home > In Car Electronics (L322) > DVD Changer not playing DVDs
Danwilderspin
Hello all,
So my 6 disc dvd changed hadn’t worked for a while it had been getting slow and then got the mecha error.
The latter is now fixed but it now picks up discs in the changer but only plays copied dvds and cds not original dvds.
Firstly anyone had this before and what was the remedy?
My initial thoughts after some googling was that the laser was getting old and the power needed increasing so I turned to the two pots half a turn clockwise in different combinations- making it marginally better in some and a lot worse in others.
From that I have deduced that the laser is on deaths door and whilst I could keep spinning them it would probably not last long.
From there I googled a new laser block... yea good luck with that no such thing exists for our changers apparently!
I then spent the evening combing through different alpine laser blocks until I found what looks to be identical with the exception that ours has the solder Unshorted the new one is shorted but this is easy to correct...
I have ordered one for £40 and will update how I get on-
https://s.click.aliexpress.com/e/dCGCg0gOr Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #537201 12th Dec 2019 3:14pm
Ian928
Norway 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I am very interested in this mod! 2006 Supercharged
Post #537229 12th Dec 2019 10:41pm
danielb
Re: DVD Changer not playing DVDs
Unnecessary quote removed
Hi there, i might be a be later to this post but i do repair these dvd changers and stock all the parts need to fix them.
let me know if you are interested
many thanks daniel.
Post #571310 30th Oct 2020 10:12am
andyt109
@danielb - can you drop me a PM about repair for this DVD changer? i haven't done enough posts yet to be able to send PM's.
I have a 2006 4.2 SC with DVD changer in the boot, no lights on it, fuse is ok. bit of moisture in the area but the amp, sat nav disc deck and bluetooth are both OK and they are in the same area.
Rear screens both turn on and just say DVD error.
cheers
Post #575909 13th Dec 2020 8:00am
Weegie
How did you fix it? As a thought, if it was a replacement unit, could it be wrong region? John
GAP iiD BT
Post #575914 13th Dec 2020 8:35am
MarkNL
Netherlands 2007 Range Rover Vogue SE TDV8 Java Black
Two days of ownership on the 2007 with factory DVD player .... and YES the Alpine DVD player in the back is stuck at disc 3 Smile
This is the sequence that worked for me. It is a combination of info from US forum Rangerovers.net and previous posts on FFRR.com.
1. Open the big slider (2 part door)
2. Pull out the fuse block nr 1 (most left in top row)
Remove the small protection lid as in pic 2 - with the 3 ultra small phillips screws ( as in second pic).
3. Use some sellotape to fix the screws and avoid they get lost (again as in second pic)
4. Put fuse block back in
. While you push the eject button, you willl see and hear the eject mechanism struggling... and probably see the small shelf at disc 3 being stuck.
5. Give it a decent whack with the back of a screwdriver just a few cm's right of the eject button / at the red/orange plastic washer
6. And BINGO ... the 6 disc changer should come out !!
7. Grease the steel eject mechanism (left and right of the small red/orange plastic washer) with some vaseline. Enlarge pic 1 for a visual.
8. Good times !
9. I have not reinstalled the small protection lid - for fear of loosing the screws at install, and the 2 part sliding cover door should do it IMHO. Mark Offringa
Utrecht Netherlands
2007 L322 / 3.6 TDV8 / Vogue / Java black
2002 Mini Cooper / 1.6 116 hp / Red + white roof / the magic back-up Smile
Gone:
2002 L322 / 4.4 V8 / Vogue/ Adriatic blue
2000 Audi A6 / V8 4.2 / Brilliantschwarz
2003 L322 / TD6 HSE / Adriatic blue
Post #588592 23rd Mar 2021 7:53pm
danielb
Hi Mark, I repair these dvd changers and cd changers, I stock all the parts needed to fix these units, turnaround time is normally a couple of days, all repairs come with six months warranty.
Just let me know if you're interested in getting your unit fixed.
Many thanks Daniel.
Post #588659 24th Mar 2021 6:59am
chrisv
Hi Daniel,
I have a 2006 XQE500060 DVD changer that needs repairing. Can you PM me with the details of your service (I've not clocked up enough posts to PM you).
Cheers.
Post #593860 11th May 2021 11:15am
