Home > Maintenance & Mods (L322) > '09 additional cup holder in center console?
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
Hi everyone,
One thing I miss in my '09 RR that I had in my '06 Honda Pilot is LOTS of cup holders. I like to keep a good supply of water on my trips.
Since I don't smoke I was thinking maybe I could modify the ash tray that's right in front of the center cubby top to a cup holder.
I've found two different parts at two very different prices.
There's this one that I can buy for under $50 here in the USA:
Land Rover FWU500011LYU
And this one that has the spring loaded cover that's nearly $350!
Land-Rover FJI500120PVA
Has anyone tried either of these in an '07 - '09 L322? Any suggestions?
Thanks!
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #575104 4th Dec 2020 9:12pm
Danwilderspin
They won’t fit... completely different console... I am in your boar and the compromise was buying the passenger end trim for a 02-05 model with the spring loaded cup holder.
Not fitted yet but sure it will be fine... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #575316 7th Dec 2020 12:37am
lschwarcz
I don't know about the less expensive one but I'm pretty sure the expensive one will fit since it's listed as a part for my RR. I'm just a bit too cheap to spend that much money for a cup holder Shocked.
Thanks!
Bournville/Ivory
Post #575318 7th Dec 2020 12:47am
Danwilderspin
Just looked at the pics it’s square and small maybe get an espresso cup in there lol. Look at the passenger side one the goes in the end trim for 02-05. Also don’t forget you have two in the back yours then have five in total... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #575325 7th Dec 2020 8:51am
lschwarcz
Yea, I didn't expect to fit a typical HUGE American drink in there! And the size does look small but I was hoping it could at least hold a bottle of water.
In the end, I may have to make my own solution! Hmmm. I wonder how much it would cost to buy a plastic injection molding machine and to make the molds Rolling with laughter.
Thanks!
Bournville/Ivory
Post #575377 7th Dec 2020 3:16pm
Danwilderspin
Are you not even considering the passenger pop out holder from the early models?
You could design an insert for the armrest and get it 3D printed with two holders in it? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #575424 7th Dec 2020 10:47pm
lschwarcz
Dan,
I've heard of the earlier model pop-up style but would it even fit in the spot where I have an ash tray? Has any one tried to retrofit the early style to my year of RR?
Thanks!
Bournville/Ivory
Post #575429 7th Dec 2020 11:48pm
Danwilderspin
I think we are talking at cross purposes I mean this:
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #575431 8th Dec 2020 12:09am
lschwarcz
Ah, I see what you mean.
My '09 does not have the cutout for this on either side nor do I know if the structure behind is there to connect that nut and bolt.
On the drivers side (left side here in the USA) my headlight/fog light switches are in that location and it's blank on the passenger side.
I thought you were talking about this cup holder that I have heard about.
https://www.ebay.com/i/193710663595
Thanks!
Bournville/Ivory
Post #575433 8th Dec 2020 12:23am
Danwilderspin
Hi Larry - my 07 doesn’t either but I bought a used one it is just getting sorted then it’s going in - it looks like it should fit Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #575443 8th Dec 2020 9:20am
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
2010MY dash doesn't have that cutout, so it's not possible Smile
Have considered doing this myself actually. The top half of the cubby is a bit wasted as the space isn't wide enough for a modern mobile. I was thinking perhaps 3d print a new tray that fits an iPhone and then make the other bit big enough for something else, wallet or something.
Could also cable route up from the bottom bin so the phone could be charged in it.
I find the RR lacking in space for a credit card too - especially when you're doing a long EU motorway trip and need it for the tolls.
That's probably a better thing to 3d print for the old ashtray, nice little credit card holder!
Post #575465 8th Dec 2020 11:56am
Danwilderspin
Same as MY07 but I'm not saying just slide it in you can source the end trim piece on eBay wit the holder included for about£40 and just fit the holder and the trim piece... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #575470 8th Dec 2020 12:32pm
Siftah
Ahhh, gotchya! I'd assumed they'd have removed it for a reason and it wouldn't fit at all, but I see what you mean Smile
Post #575482 8th Dec 2020 1:50pm
lschwarcz
Dan,
So you bought the end piece for the passenger side or passenger and drivers side? That slide-out cup holder appears to go right were we both have our headlight switch.
If this works, it could at least be a good solution for the passenger!
For me one small issue could be that I have the Autobiography trim so I would need to see if I can find an end cap with the matching wood finish.
Please keep us updated and pictures! Lots of pictures showing how you did it and how it turned out!
Thanks!
Bournville/Ivory
Post #575499 8th Dec 2020 5:33pm
Danwilderspin
Mine is piano black ab trim which was t available in 05 but have a burr one I’m going to spray. Yes the cup holder is the same size as the headlight switch even same orientation so you could get a uk driver trim from a ab in theory and then side the holder in Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #575524 8th Dec 2020 11:07pm
