![]() | Home > Technical (L405) > SDV8 2016 Auxiliary Heatee |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8679 ![]() ![]() ![]() |
It will Not necessarily have come with the remote. Check in the menus if you have timed climate, remote lark heat was an option, but iirc they come with the heater to help with warm up as standard, the ability to control it separately is the option. There is nothing that can't be fixed with a hammer😜😜
cupples8267 Member Since: 20 Aug 2020 Location: Stg Posts: 66 ![]() ![]() ![]() |
Thank you very much. That makes sense |
jumpin mouse Member Since: 28 Feb 2016 Location: North West Posts: 222 ![]() ![]() ![]() |
I would expect a Vogue SE to have timed climate but remote park heat is the ultimate. |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
My previous SDV8 Vogue SE 4.4 (2015MY) had timed climate, but it did not show on the control screen and had to be turned on using the IID tool. So worth a check to see if you have a menu option for timed climate. SDV8 AB MY 2019
bear100 Member Since: 22 May 2011 Location: south wales Posts: 204 ![]() ![]() ![]() |
My autobiography came with this remote to activate the park heater
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 771 ![]() ![]() ![]() |
I order to make more use of the FBH, you may want to check out my guide on how to retrofit remote park heat and activate timed climate...
