Home > Technical (L322) > FBH has a mind of its own
HS66
I’ve noticed the FBH seems to be active when the car is parked up it’s turned off but has been on when I’ve come out to it a bit later, I did press the on button and off button on the remote, is there any way to disable it coming on or just have it on the timed climate setting in the car itself?.
Any help would be appreciated.
Post #567505 19th Sep 2020 8:49pm
NDT
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
I think it has to finish a cycle if it has started one.
How long after you parked is it still on?
Post #575052 4th Dec 2020 12:41pm
Weegie
Should switch off if you press the off button. Mine does as did my Td6 when I had it. John
GAP iiD BT-Sold
Post #575054 4th Dec 2020 12:53pm
kevinp
I havn't got a remote for mine but it's started working since the temperature has dropped.
Post #575055 4th Dec 2020 1:00pm
mjdronfield
I’d say that’s working as normal. It’s primary purpose is to help the engine get to temperature faster. The climate stuff is just a bonus.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #575061 4th Dec 2020 1:44pm
kevinp
Post #575136 5th Dec 2020 10:38am
