Home > Technical (L322) > Replacement Air Struts
ash27
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Hi all,
So I was out with the car (07 4.2 SC) investigating my annoying water leak, will post a different thread on that, and had the car parked in off road height to check the aircon drains (with a jack in case the car did anything silly). Popped back into the house for a tea and locked the car up.
Came out to the alarm going off and as I got closer I could hear hissing from the front driver side air bag and slowly watched it deflate. Big Cry
Its now parked up slammed on the floor like I have just had my ride pimped by Xzibit.
So a few things I want to check before ordering replacements, after much reading on this forum!
1 - Is it OK for the car to sit on the floor whilst I get the parts sorted, i.e. this wont damage the rears?
2 - I am going to replace both front struts for ease, is the following a pretty complete list of parts (assuming no issues outside the strut itself)
- LR032563 L322 Right Front OEM Shock Absorber RNB501520 x1
- LR032570 L322 Left Front OEM Shock Absorber RNB501530 x1
- KYG000031 M16 X 65MM BOLT HUB CARRIER MOUNT (2 PER SIDE) x 4
- KYH000051 Nut M16 x4
- AirStrut Spring Gasket Front (Genuine) RYF000141 x2
- Plastic clip that always breaks - did find a thread on this and will look again before ordering
3 - Whilst not wanting to talk specifically around pricing (due to site vendors) the cost of the struts is quite different say looking at Advanced Factors and Island 4x4. I can only find good reviews for both on the forum itself so any reason to pay the higher price?
4- I assume these are the original struts:
Nicely cracked up bag
Many thanks for any and all help
Ash 07 4.2 Supercharged
Previous:
2011 Volvo v70 D5 | 2009 Honda S2000 | 2010 Mazda MX5 2L | 2006 Vauxhall Astra VXR | 2002 Hyundai Coupe 2L | 2002 Saxo VTR | 1999 Saxo 1.4 | 1999 Saxo 1.1
Post #574759 1st Dec 2020 2:00pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
When mine went i simple replaced the front pair with these
https://www.jgs4x4.co.uk/range-rover-l322-...ir-dunlop/
they were perfect that was on a 2004 TDS FFRR. Dunlop as i understand were one of the OEM mfrs for these parts just no LR logo on them.
did about 10k miles on them now squeeks rattles or anything just a great ride Mr. Green Thumbs Up 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #574766 1st Dec 2020 2:55pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
1. No, shouldn't be a problem just obviously don't drive anywhere like it.
2. Yes, should really replace both struts as a pair as they contain the dampers and wouldn't suggest to have say one new damper with zero miles wear on it and the other unchanged with 100k miles for example. There are times where you might only change one, say if the other is relatively new too or adaptive damping regulates them (depending on how it works).
Can't remember if I used new nuts and bolts, depends on what tools you have available for removal, mine came off and out fairly easily with an Impact gun and they were on the vehicle from new and over 12 years old.
3. I've always used Island 4x4 for parts and they've always been good OEM parts with low prices, OEM struts I bought from them quite a few years back were Delphi, the same as originals.
I can't comment on other places other than the Advance Factor web picture shows OEM as a BWI manufacturer. A little more digging and BWI is BeijingWestIndustries which acquired Delphi's chassis division in 2009. So it could be Delphi are in fact now sold as BWI and are the new equivalent OEM. I wouldn't buy anything else other than these two, others are known to fail prematurely, if OEM Delphi/BWI can last over 10 years and 100k miles then that's good enough for me.
Post #574770 1st Dec 2020 3:18pm
mjdronfield
When I had my TD6 I purchased 2 Delphi units from island 4x4. Had no issues.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #574771 1st Dec 2020 3:28pm
LR used Delphi, NOT Dunlop. Your photo tells you so.
Use Delphi/BWI.... .
Post #574780 1st Dec 2020 5:40pm
Discotigger
As Joe90 says, OEM airbags are Delphi not Dunlop. People who got Dunlop airbags have had problems with them in the past.
I got OEM Delphi bags from Island 4x4 when the old ones went on my old TD6, easy(ish) to replace.
Post #574785 1st Dec 2020 6:33pm
Jayk69
Well my experience was flawless 2012 Vogue 4.4 TDV8 - Current
Post #574789 1st Dec 2020 7:10pm
ash27
Thanks for the info all.
Placed the order for the parts along with a few other niggling bits like bonnet and tailgate struts that are on their way out so hopefully none of the bolts will give me issues. Will get the +gas on them asap Smile
For reference as Island 4x4 don't state it on the product page I could see they did confirm that "We only sell the Genuine OEM struts made by BWI." so that's good news Thumbs Up
Will follow up in my "My Range Rover" thread to hopefully the good news of fixing it. Now it feels like proper RR ownership Laughing 07 4.2 Supercharged
Previous:
Post #574869 2nd Dec 2020 4:10pm
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
I've been out for a couple of days so too late, but my minor write up of doing the same job on a 2011 vehicle with adaptive dynamics was here: https://www.fullfatrr.com/forum/topic54196.html . Hopefully you did find the little plastic clips in time!
I soaked my fixings in penetrating oil for a few days in advance of doing the job, and thankfully had no majors issues using a big enough breaker bar, everything came out nicely. I did order the new knuckle bolts/nuts at the same time just in case as they weren't that expensive, and whilst all mine ended up coming out clean, I was a bit happier knowing it was all new and hopefully good for another 10 years!
Post #575114 4th Dec 2020 10:28pm
