Home > Technical (L322) > Cut out, no ignition lights, communication faults |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1751 |
Dash has to be stripped to access the switch, unfortunately |
1st Dec 2020 12:45pm |
RRTDV83.6 Member Since: 22 Oct 2020 Location: Devon Posts: 8 |
I was hoping for a miracle! If I knew where the switch outputs went I could test for a live but I cant find the wiring diagram for the ignition on technical date unfortunately. Cheers |
1st Dec 2020 1:22pm |
UPDATE. All sorted, I pulled the ignition switch out stripped it and cleaned up the contacts with diamond contact cleaning blades. Started up and warning lights all clear. |
1st Dec 2020 9:06pm |
