Home > LPG > LPG issues...... rough running |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1276 |
Dunno, probably not going to the pub though |
29th Nov 2020 9:54pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 841 |
First check your lpg filter this time of year with the colder weather a poor filter will mess things up.
29th Nov 2020 10:37pm |
udnyrangerover Member Since: 20 Sep 2020 Location: aberdeeshire Posts: 13 |
I can work way through most LPG systems quite good.... so here goes
29th Nov 2020 10:54pm |
Super7 Member Since: 23 Feb 2019 Location: Somerset Posts: 19 |
if you've got gas at the vaporizer and it stays on gas your solenoid shut of valves and temp and pressure sensors are unlikely to be the cause, don't forget you have a liquid filter in or before the vapouriser as well as the vapour filters prior to injector.
29th Nov 2020 11:46pm |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 332 |
I suggest that it may be one or two of the LPG injectors which will pack up over time. If you have a spare rail, I’d be putting that on or swap the rails around to see if the fault moves sides. |
30th Nov 2020 6:41pm |
