Home > Maintenance & Mods (L322) > Td6 thermostat Renault 5 mod
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
I didnt even bother trying to get to the clip engine end, same as you just moved the dipstick tube over and cut clip with dremel type tool ( aldi really but does all I need) use universal joint on 1/4 drive socket to tighten up jubilee clip.
Post #574481 29th Nov 2020 12:16am
Ianb4310
Stuart 2006 where did you get the hose from ? and what size jubilee clip did you use ? Is there no chance of saving the old hose ? Sorry for all the questions
Post #574487 29th Nov 2020 7:02am
stuart_2006
You can use the current hose as long as you don't damage it cutting the clip off (and it's in good condition, obviously). I just wanted to get a new hose so I had the original as a spare if it all went pear-shaped. New hose was from Island 4x4 (Kent):
1 x HOSE ASSY (Genuine) PCH001221 (PCH001221LR) = £24.99
Sub-Total: £24.99
UK Delivery (FedEx Courier) (Standard): £5.00
VAT 20%: £6.00
Total: £35.99
Jubilee clip is stainless steel 35-50mm (eBay item eBay Item No. 390845362916, many others available). Make sure you have a spanner or socket to tighten the clip with - no room to get a screwdriver in there.
Didn't bother putting a Jubilee clip around the thermostat itself - it makes a bit of a bulge in the pipe and I can't imagine it moving.
Post #574561 29th Nov 2020 6:25pm
Nismotec
nicely done.... i did this mod to mine a year ago and it hasnt missed a beat. the temperature gauge sits at half way,and the mpg has gone up.. a good result all round
Post #574710 30th Nov 2020 10:53pm
Ianb4310
It’s a bit late I know but finally got round to doing this works a treat thanks for the help
Post #586825 9th Mar 2021 5:56pm
