Home > Technical (L322) > 2011 4.4 l322 P0486-17 fault |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
P0486-17 Exhaust gas recirculation sensor B is the sensor in the actual EGR.
Have a look in the WIKI section I believe the workshop manuals are there Also have a search - you'll see helpful results such as:
The EGR is on top of the 'V' so relatively easy to get to. Check for boost leaks too (use search for loads more info on these) and also you'll do them a favour by cleaning anything you remove such as the throttle body. Are you reading that code straight after you get restricted? And doe the restricted clear when you clear all errors? . . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
29th Nov 2020 8:32am |
scrappyloz Member Since: 16 Dec 2019 Location: Hereford Posts: 6 |
Thanks for the reply.
29th Nov 2020 9:30am |
a few thoughts:
29th Nov 2020 10:23am |
I would agree with you on the boost leak if it came on when driving. But it only happens on startup.
29th Nov 2020 12:21pm |
boost leak - yep sure but it's worth double checking the hoses just in case.
29th Nov 2020 12:31pm |
Sorry i meant when the temp sensor is unplugged if gives a fault code but not the same one i currently have. I will do a boost leak test tomorrow and go from there. I personally think its an electrical failure somewhere else. Worst case a sticking egr valve maybe |
29th Nov 2020 4:49pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
I had an issue a few weeks back, not the same sensor but strange behavior.
4th Dec 2020 4:22pm |
Thanks for the reply. The fault turned out to be the egr sticking intermittently when first started i could see it happen briefly on live data.
6th Dec 2020 2:51pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4303 |
Who’s mapping it out? How will the DPF cope with that? I thought the 2 were reliant on each other.
6th Dec 2020 5:53pm |
The customer decided to get the egr mapped out. It was not mapped by myself but the person/company who did it said that it will not effect the dpf. Im unsure how they can say this but its up to them.
1st Jan 2021 10:19am |
