Home > Technical (L405) > Heated and Cooled seats
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
2013 Range Rover Vogue SE 4.4SDV8
My RR has heated and cooled seats. The heated seat base does not seem to get warm when the heated seat is selected. The seat back gets warm but the seat bases do not. All lights are on and the controls seem to work. Anybody got an idea as to where to start looking?
TIA
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #573801 23rd Nov 2020 10:54am
swissomatic
United States 2015 Range Rover 5.0 SC V8 Fuji White
North east coast of Australia or Florida.
Post #573818 23rd Nov 2020 2:06pm
/\ best advice above.
However, if stuck with the UK - when you say all lights are on, I assume you mean that the base lights are on ? There are separate lights for the back & base - just thought I'd check the obvious first Embarassed
By 'bases' do you have the same fault both sides ? That would seem particularly odd.
There should be something in this lot, bit not sure where Whistle
Post #573819 23rd Nov 2020 2:25pm
IGP
Funny enough I used to live in Brisbane Australia!
Neither seat base gets warm. When you select the heated seats and then select all zones, the lights on the display show the seat back and the seat base in Red (i.e. heated). I do not seem to be able to select just the seat base. My options are seat base and back or just seat back.
Hope that's a bit clearer.
Regards
Post #573895 24th Nov 2020 11:20am
supershuttle
When Idling my time away I noticed in the thread "What did you do in your Range Rover today" or something like that someone had fixed this maybe you might want to contact them. Geoff
Post #573901 24th Nov 2020 12:26pm
