Home > Maintenance & Mods (L322) > Preventative maintenance |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35412 |
just looked at the inspection 1/2 sheets in the wiki and there's not mention of PAS fluid being changed..
23rd Nov 2020 11:21am |
Cavalier Member Since: 04 Sep 2015 Location: Bletchley Posts: 189 |
Thanks for the quick reply Stan, I think I will let him do it. I’ll post the cost when the car comes back from service. It’s going in on the 14th Dec. Also having the starter motor changed, had the dreaded click a few times this year. |
23rd Nov 2020 11:43am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4308 |
Ask him how he changes the fluid. I want to do mine. Was going to do the syringe and fill method repeatedly Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
23rd Nov 2020 1:17pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
If it's of any use I changed my power steering fluid recently after 90k and 16 years. Simply used the siphon out and fill method, repeated until the fluid was bright green. I bought a one litre bottle of fluid and after about 7 changes had emptied the bottle.
23rd Nov 2020 1:27pm |
Job for weekend.
23rd Nov 2020 3:29pm |
^^ Did the first few changes switching the engine on each time, after that I just did a change after I had been using the car until I finished the bottle. |
23rd Nov 2020 3:52pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1233 |
Had to have a new rack on my 2011 because it was leaking. It cost £3400 so I think any preventative work is worth it. |
23rd Nov 2020 6:24pm |
Did you notice any fluid on the floor, that. At have given you a hint you were loosing fluid? |
23rd Nov 2020 8:51pm |
23rd Nov 2020 8:52pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
I did my 405 @ 5yrs old & 50k miles... |
24th Nov 2020 12:18am |
The undertray had a few drips of oil coming off it. I thought it was leaking from the front drive shaft initially. |
24th Nov 2020 12:45am |
