Home > Wheels & Tyres > introducing new Spare wheel and tpms
CMJ
2015 Range Rover Autobiography TDV6 Santorini Black
I have recently replaced my spare wheel with a brand new wheel and tyre. Despite having the correct pressure in the wheel the tpms is reporting low pressure when starting the car. I have read this evening that if you introduce a new tpms sensor as the spare wheel this will need reseting and coding to the car. If however you put the new wheel on an axle this should automatically be recognised by the car within a period of driving. Can anyone confirm if the above is true ? If so I will stop fiddling with tyre pressures and go and get the tpms reset.? 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #573776 23rd Nov 2020 12:25am
CMJ
Can anyone tell me if a typre shop can code tpms or do I need to go to a LR specialist.? 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #573994 24th Nov 2020 10:03pm
CS
MY 17 does it automatically when wheels are put on the car (i.e. the driving wheels) so if your spare wheel/tyre size is compatible with what you have on the driven wheels you could try putting the spare on one of the driven wheel positions. Not sure if earlier MYs the same though. The fact you are getting a reading from the spare however suggests that the wheel is recognised by the the car, could it be that the sensor is defective? Maybe try over inflating it to trick it into stopping warning you? You can always let some air out if you ever come to fit the spare. My experience has been that spares tend to signal low pressure when the weather gets colder, but measuring the pressure has shown them to be maybe a pound or so down, adding some air has solved it the last two autumns. Only Range Rovers since 1988
Post #574046 25th Nov 2020 12:47pm
had the same problem with my spare when it lost a little pressure due to not being used and it read nearly the proper 'on the road' pressure..
i increased it to 45psi and have had no error readings since... ... - .- -.
Post #574060 25th Nov 2020 1:50pm
CMJ
Thanks gents. Have inflated to 60 and still no better. May flatten and try again to see if it kicks the sensor in if not I think it’s a manual tpms reset. The wheel was taken from another vehicle as someone had swiped the one from mine. Before I picked it up. 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #574133 25th Nov 2020 11:01pm
