Home > Technical (L322) > 2003 power steering |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
It could possibly be the servotronic valve on the rack is playing up, or may need a refresh of the power steering fluid, or a new pump.
18th Nov 2020 9:57pm |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 |
Cheers mate. Soon as your moving it becomes pretty heavy even at 5mph so I'll give that servotronic valve a try. These easy to change or best left too a garage? |
19th Nov 2020 4:55am |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 689 |
Try putting a separate 12v feed to the servotronic valve after disconnecting the normal loom connector (its best done with another connector as the pins are too fine to resist any misalignment).
19th Nov 2020 9:25am |
Bcm was changed a few months ago now. Had the same problem before it being changed |
19th Nov 2020 11:14am |
