Home > Maintenance & Mods (L322) > Denso starter motor
Cavalier
2011 Range Rover Vogue 4.4 V8 Orkney Grey
Denso starter motor
I’m about to get my Indie to change the starter motor on my 2011 4.4, you know the odd click every now and then when trying to start. It seems Denso make the starter motor for LR. By having a Denso fitted, am I just buying into the same fault as I have now, ie burnt solenoid contacts. Or have Denso improved this weak spot on there motors? I notice there are other makes of starter motor, but I like to use OE parts were I can. Anyone got an opinion?
Post #573206 17th Nov 2020 2:00pm
DrRob
I'd stick with Denso. Most have on here with no issues...I think it's just a wear and tear thing... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #573210 17th Nov 2020 2:17pm
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
don't know how many miles your car's done (or more relevantly - how many starting cycles) but mine is still on original OE starter at 110k
Post #573217 17th Nov 2020 3:02pm
Cavalier
42K miles but as you point out, I suppose it depends on the number of times the solenoid has been activated. Annoying when you think there is nothing wrong with motor, apart burnt contacts.
Post #573234 17th Nov 2020 5:07pm
Baltic Blue
Fit a new replacement, then strip and clean the contacts in your old one for a free replacement ready for next time it fails.
Mike.
Just be careful opening it up, then it’s only 15 minutes of a job once it’s on the bench. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #573237 17th Nov 2020 5:22pm
Cavalier
I did find a site today that sells Denso solenoid replayments. Could find one for ours though. But if they make them for lots of others, I wonder why they don’t do LR032541.
Post #573243 17th Nov 2020 5:59pm
Baltic Blue
Good luck with your search, but I don’t think you will find the bits we all need.
I took mine to a local specialist Auto electricians who spends
all day repairing and replacing starter motors and alternators, but , with all his contacts, he failed to find them .
Their is plenty of meat in the contacts, so will file down a couple of times.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #573247 17th Nov 2020 6:16pm
Baltic Blue
Further to my previous reply....
I think some form of anti spark grease such as used in heavy duty electrical switch gear is worth further investigation.
Electrolube is a possibility.
Post #573251 17th Nov 2020 6:43pm
Cavalier
Managed to order a new Denso to day, good price, £200 using a £50 discount voucher. I will have a go at refurbishing the contacts on the old starter, see what they look like.
Post #573316 18th Nov 2020 2:12pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
i had what i thought was a problem a click every now and then when pushing the button. turns out a battery charge and hold the button until the car begins to turn over problem solved. i think the issue in my case was releasing the starter button too early Mr. Green 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #573321 18th Nov 2020 2:56pm
