Home > In Car Electronics (L322) > Does replacement display need to be coded to my vehicle?
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
UPDATE: January 15, 2021 (yes, the USA format!)
I bought a used display off of eBay and it was plug and play. No special coding of the part to work in my car.
Hi everyone,
The radio/navigation display is having the (apparently common) issue of flickering. It's very annoying and I'm exploring my various options.
If I have to replace it with either a used or new one, do I need to code this part to my particular vehicle or are they plug and play?
If it has to be coded, will most of the diagnostic tools do this? There are a bunch of them and I'm still exploring which would be the best for me.
Thanks!
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #573012 16th Nov 2020 3:22pm
mjdronfield
I’ve never done it, but I have never heard of coding to the vehicle being required.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #573014 16th Nov 2020 3:49pm
lschwarcz
ANSWER: No, there is no special coding or anything to replace the radio/navigation display. Just unplug the old one and plug in the new one.
The hard part is disassembling the whole top of the dashboard to access the unit! Once you've done that it's easy Smile.
Thanks!
Bournville/Ivory
Post #579933 16th Jan 2021 12:17am
UK cars DEFINITELY need coding! The screens are VIN locked on 2009>MY here sir... Thumbs Up
Post #579936 16th Jan 2021 1:16am
lschwarcz
Cam-Tech-Craig,
Is that the 3rd gen L322 with two buttons above the knobs on each side you're referring to? I'm talking about the USA spec second gen L322 with three buttons above the knobs on each side.
I was not sure and just bought one from a local wrecking yard and it just plugged straight in.
But that's good information to know for when I eventually buy a 2012 L322 in 4 years or so (when they become more affordable for me Very Happy).
Thanks!
Bournville/Ivory
Post #580019 16th Jan 2021 5:12pm
Hi Larry, yes i was expecting your 09 to be a third generation (LCD dash) but clearly its not?
So, for anyone reading this in the future UK markets 2009-2012 radio screens are VIN locked Thumbs Up
Post #580077 17th Jan 2021 1:52am
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
What's the process to change that?
Post #580507 19th Jan 2021 9:14pm
lschwarcz
JNC,
The radio/navigation display in your 2011 FF is a different model than mine. I'm guessing that the whole process to remove it is also different.
I would suggest that you check out the service manual or look for a YouTube video.
Good luck!
Bournville/Ivory
Post #580509 19th Jan 2021 9:23pm
The dash and the way its removed to reach the screen is almost identical from 07my> the run out 12my Thumbs Up
Post #580516 19th Jan 2021 11:28pm
