![]() | Home > In Car Electronics (L405) > CarPlay upgrade |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
have you seen the thread just below this one....... ... - .- -.
bear100 Member Since: 22 May 2011 Location: south wales Posts: 204 ![]() ![]() ![]() |
Hi Stan, I did see it but it’s mostly heard for the slightly older version I’ve got the 2016 model AB
you must have the same home screen like mine,
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 347 ![]() ![]() ![]() |
When you say "the upgrade", which one? NaviPlus? There's a few of us have fitted the NaviPlus to L322's, it's the same basic kit for L322 and L405 so we can probably offer opinions on the non-L405 specific bit of it ![]() |
Yep that’s the one Stan same as mine.
W84IT Member Since: 14 Sep 2019 Location: Indio, California Posts: 43 ![]() ![]() ![]() |
Ray
looks like that will be ok Bear, but a email/phone call to confirm would be a good idea....
My thoughts too! It’s nice to have and around £250/300 would be about right.
If I'm not mistaken, I think you will loose your original Navigation with that setup...it seems very similar to the NaVTool which uses the factory Navigation button for CarPlay/Android Auto. The factory navigation is a good feature to have available if you're out in the wild and your phone looses signal. The 10.25" Android unit actually retains your factory navigation and all of your other factory features except the dual view. Please do your research before you purchase. Ray 2016.5 L405 (Fuji White with Ebony Interior) 2020.5 Defender 110 P400 HSE (Fuji White with Ebony Interior) |
If it's using the NetPlay box (like the NaviPlus does), then you can program it to respond to whichever of the buttons you want to use.
brutprestige Member Since: 10 Nov 2020 Location: Westchester Posts: 11 ![]() ![]() ![]() |
Can anyone shine a light- LR apparently offers a complimentary update for 2016-2018 to enable apple carplay, but nowhere can I find which models are eligible. I have the same system by the looks of it as Stan (with the touch-buttons on the sides) in my 2016 RR- would the LR update be available?
the LR software upgrade for carplay is only for the newer 17my screens without the hard side buttons .. ... - .- -.
Stacey007 Member Since: 03 Nov 2020 Location: Cheshire Posts: 18 ![]() ![]() |
Thanks Stan- so also wont work with the ‘touch’ side buttons I guess? |
