![]() | Home > Maintenance & Mods (L322) > Egr delete problem |
Ianb4310 Member Since: 21 Sep 2017 Location: Gainsborough Posts: 201 ![]() ![]() |
No one had any similar problem |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Some Photos might help |
This is the one I’ve fitted, where the part circled in red joins the stainless steal cooler pipe I cannot get a good seal |
This is the joint circled in red I can’t get it to seal properly |
DomenicoSpano Member Since: 15 Oct 2020 Location: Kortenaken Posts: 5 ![]() ![]() ![]() |
You need to fully open them (like fully non attached anymore) and then reattach it Last edited by DomenicoSpano on 16th Nov 2020 6:32pm. Edited 1 time in total |
but then again the question stays.
How do you do that? |
Do what ?
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
The reason not to remove it is an obvious EGR or DPF delete/bypass is an MOT failure in the UK.
The clamp was broken but must have overtightened it ! Ordered a new one off the bay and fitted sealed up nicely thanks |
