Home > Maintenance & Mods (L322) > Steering wheel..aghhh |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
These can be very fiddly. You need a small long screwdriver to fit in the hole. You can release one & then have it locate again, when you attempt to release the other side.
12th Nov 2020 6:50pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7797 |
I put a new steering wheel on my TD6. Getting the airbag off was the worst bit
12th Nov 2020 8:13pm |
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 285 |
On my D3 I got an air bag removal tool. You have to locate the tabs inside and pull them outwards to release the airbag. There is a video by Powerful here that shows how to do it.
13th Nov 2020 9:36am |
Ivan, Different tool & process for the L322 unfortunately.
13th Nov 2020 9:46am |
OK no worries 2013 Vogue SE SDV8
13th Nov 2020 9:47am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
@DaveK, You just have to keep fiddling with it until you hit the right spot.
13th Nov 2020 12:58pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2643 |
absolute ballache of a job, took me fooking ages and a gallon of patience. |
13th Nov 2020 1:36pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 891 |
This should help, have a look at my flappy paddle thread I made a special tool from a screw driver and took loads of photos to help.
13th Nov 2020 7:08pm |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 790 |
Finally removed with a lot of assorted things poked in the tiny holes ! That done, clock spring was a breeze. |
14th Nov 2020 12:28am |
Gsxr1250dave's photo's should have helped. Looking at the second photo, you can see that it's missed a few times & how tricky it is. |
14th Nov 2020 9:18am |
