![]() | Home > Technical (L322) > Replacing Restraint Control Module |
Pikey Member Since: 11 Nov 2020 Location: Cheltenham Posts: 39 ![]() ![]() |
I've just bought an 06 L322 - on test driving it I noticed the airbag light was on, the garage offered to put a fresh MOT on the car for me, and fix the airbag light issue as part of that.
Ha - just noticed you're also in Cheltenham |
cipenman Member Since: 08 Nov 2020 Location: Cheltenham Posts: 3 ![]() ![]() ![]() |
It does say that but I have read a number of posts about people just replacing them that I wanted clarification. Did your garage try reprogramming it? or just do as I did and replace it? And yes quite a coincidence that we are both in Cheltenham ![]() |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 475 ![]() ![]() ![]() |
The module definitely has to be coded to the vehicle using some quite expensive diagnostic equipment, a good Indy will be able to do this for you but if not the main agent can, it usually costs around £70 to have them coded. Not unreasonable when you consider the price of the equipment needed |
Thanks Dave.
Which garage is that?
