Home > Off Topic - Other Cars > Discovery 5 not 4 ( sorry )
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Hi all , quick question, a customer of mine has a 2016 reg discovery 4 and I put my IID TOOL on it today to clear its faults . It has one fault that won't clear and thats U0102-00, communication with transfer case module. I couldn't see how to select low range so couldn't check to see if it worked. I assume all disco 4 s have low range so could some one point me towards where the switch is please ? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #572387 10th Nov 2020 6:42pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
Should be the same as a RRS, so a small rocker switch on the panel below the gear selector dial, drivers side I think. The opposite switch is the suspension raise/lower
Post #572388 10th Nov 2020 6:55pm
dolph34
@Andy s , thanks for the prompt reply , when sitting in the drivers seat there is a panel in front of the gear selector which has four terrain modes on top and then the lower / higher rocker switch with hill desent and the Eco button for the start stop but no switch for low range that I could see. I'm not sure of the spec hence why I wondered if they all had low range . 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #572389 10th Nov 2020 7:04pm
Yep they all do have low range, at least I’ve never heard of one without....
Has someone replaced that switch with one out of an ewok or disco sport?? Disco sports don’t have low range!
Switch looks like one of these depending. But I would suspect the bottom one....
It is the right hand rocker switch...
Not seen a D4 with eco mode..... ever...... stupid question, are you sure it’s a D4?? There is nothing that can't be fixed with a hammer😜😜
Post #572400 10th Nov 2020 8:24pm
dolph34
Hi Northern Monkey, not a stupid question at all , its a 2016 so I assumed d4 but just spoke with him and its a D5 , my apologies to all who have read this . 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #572405 10th Nov 2020 8:49pm
dolph34
Its what I call the older shape so I thought it was a D4, thats my excuse and I'm sticking to it. Bow down 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #572408 10th Nov 2020 8:53pm
dolph34
Thanks to Northern monkey a good search has revealed that low range was an option on D5s , if this is correct could that explain the loss communication fault code ?? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #572410 10th Nov 2020 9:01pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
There's a D5 area on the D3 / D4 forum. You could ask there? 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #572411 10th Nov 2020 9:01pm
dolph34
Thanks MikeO Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #572412 10th Nov 2020 9:02pm
dolph34
Thanks to all that answered, apparently D5 have optional low range Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #572414 10th Nov 2020 9:13pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Dolph34, officially you are a Censored , I was at a loss to understand your issue but no matter, spent some time looking for an answer, you better have a word with yourself before you ask another question Rolling with laughter
Post #572415 10th Nov 2020 9:28pm
dolph34
Apologies again , no more questions for atleast a month and definitely none unless they relate to my FFRR . Its amazing I can find my way to work Very Happy 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #572417 10th Nov 2020 9:33pm
Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #572418 10th Nov 2020 9:40pm
Rosco
Good man Rolling with laughter
Post #572421 10th Nov 2020 10:07pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
They don’t - from 2014 they could come with a single-speed transfer box and a Torsen centre diff.
Post #572430 10th Nov 2020 11:11pm
