Home > Technical (L322) > Rear Demist not working
neil3728
United Kingdom 2013 Range Rover Vogue SDV8 Baltic Blue
The rear demist is not working in my 2011 Vague, never an issue till its starting to get cold now, could really do with it fixing, had a little look around all the fuses all seem to be okay.
Before I start taking the trim apart and probably break a piece of the trim is there anywhere I should be looking.
Thanks 2013 Vogue 4.4 TDV8
2014 Defender 110. now sold
2018 Range Rover Sport.
Post #572372 10th Nov 2020 5:04pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Probably need a new rear window mate. As far as I know they work the same as the front heated screen
Post #572378 10th Nov 2020 6:08pm
neil3728
Typical, I was hoping for an easy fix similar to my defender where it had just come unplugged.
My front screen os not that great either, looks like I might end up replacing both. 2013 Vogue 4.4 TDV8
Post #572379 10th Nov 2020 6:10pm
take the trims off and check you have power going to the window elements...
if no power look for breaks in wiring or fuses blown.
if power then the window will probably need replacing.. ... - .- -.
Post #572381 10th Nov 2020 6:25pm
bishbosh10
I had / have this problem. Not the screen, not the fuses, not the switches.
Turns out (after a grown up plugged her in and diagnosed her) it is a relay on the fuse board behind the glove box. The relay is integral with the fuse board.(WTF!) The fuse board is £500. (insert expletive here!)
To be honest, I don't really miss it until I have two soaking wet panting dogs in the boot, otherwise the cabin demists it quick enough for me. Certainly not dropping £500 plus fitting just to get it working again.
You may be luckier..... Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #572493 11th Nov 2020 2:20pm
