Home > Maintenance & Mods (L322) > Rear bulb change
TonyB
Rear bulb change
2012 Westminster.
I have removed the light cluster housing and removed the 4 retaining screws on the housing.
The housing will not part from the lens.
Can anyone advise what step I have missed.๐Ÿ˜ณ๐Ÿ˜ณ๐Ÿ˜ณ
Thanks!!!!!
Post #572083 7th Nov 2020 2:46pm
jordon0
United Kingdom 2010 Range Rover Vogue SE TDV8 Zermatt Silver
sorry but the lens/cover are all one unit ie can't be split to take light units out
Post #572095 7th Nov 2020 3:36pm
TonyB
Many thanks. So, any bulb goes then the entire cluster is unservicable?
Post #572097 7th Nov 2020 3:39pm
jordon0
yes if any of the leds go out a whole new unit is needed
Best bet is try a wanted ad on here as likely to be cheaper than ebay/breakers etc
Post #572100 7th Nov 2020 3:48pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Check that it is not a wiring issue using a multimeter before you go to the expense of a new light unit. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #572104 7th Nov 2020 4:44pm
The rear lights on a 2012 are fully LED, no bulbs to change. If you have a light out then you either have a wiring issue as said or a duff light unit.
Iโ€™m pretty sure the plugs on L and R are the same so easiest way to check the light would be to take both out then swap
Them side to side and see if the duff bulb moves with the swap. There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #572105 7th Nov 2020 5:25pm
TonyB
Thanks for the tip! Very Happy
Post #572113 7th Nov 2020 6:59pm
