Home > My Range Rover > Have taken the plunge.....
range366
Scotland 2004 Range Rover Vogue 4.4 V8 Java Black
And after 20 years of petrol range rovers, (Classic, P38 and L322) I have now opted for a Stornaway Grey 2011 4.4 TDV8. Here she is pictured next to old faithful (which will now be put up for sale if anyone’s interested)
After a week of ownership, very impressed with it, it can fair shift when you want it to! And quiet too, inside the cabin.
Had it serviced right after I bought it and only issue found was a leak in one of the suspension air bags, along with a cracked rear tail light cover.
One question I do have though, is there a knack to filling up a diesel rangie? I’ve only filled it twice but the pump nozzles keep getting splash backs and keeps cutting out... takes ages to fill it up, but apart from that it drives great Thumbs Up
Post #572029 6th Nov 2020 11:08pm
cass
Have you checked the yellow mis fuelling guard?
Post #572032 6th Nov 2020 11:16pm
range366
Mis fuelling guard? Can you explain a bit more please?
Post #572033 6th Nov 2020 11:23pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
https://www.fullfatrr.com/forum/topic6435....ellow+boot
If you put a petrol filler nozzle in it triggers a flap to kick back the fuel flow. To reset it thee should be a yellow plastic tool in the car...try the boot or glovebox. Alternatively try a large long screwdriver.
It is in mentioned in the handbook or try search above 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #572034 6th Nov 2020 11:46pm
range366
Thanks for that, will have a look in the morning Thumbs Up
Post #572035 7th Nov 2020 12:08am
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
So, it's not just me then? I've asked the same question because I get the same problem on both of our 2010 4.4 TdV8's and no, the misfuel guard hasn't been operated. It seems to be very fuel pump dependent, some pumps work fine and others are a right PITA. You just have to fiddle around with nozzle angles until it works, or move pump! It could be down to servicing of the pump triggers, as the less used pumps at our local Shell work fine, whereas the more used ones can be problematic. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #572043 7th Nov 2020 8:40am
Turn the fuel hose upside down.
Weird I know but mine was a pain to fuel and flipping the handle on the hose upside down meant I could fill it full throttle👍🏻 There is nothing that can't be fixed with a hammer😜😜
Post #572055 7th Nov 2020 10:52am
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
I've found that holding the nozzle so that it's parallel to the ground works with mine.
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #572056 7th Nov 2020 10:52am
mjdronfield
I picked mine up when I bought it, went to nearest garage to fill with fuel, still there 2 hours later having called the garage out. Still the same 5 years later.... can only put nozzle in a bit or misfuel thing comes on.... right pain.
The release tool was even in the drivers door pocket 🤣
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #572060 7th Nov 2020 11:36am
range366
When I bought it from the car dealer there was 3/4 a tank of fuel in it, which i thought most odd for buying a new car...
Anyroads, had look this morning and sure enough the yellow filler guard has operated, unfortunately I can't find the reset tool anywhere, however I did find some various tools and an unused towing strap complete with towing eyes stored at the back of the spare wheel Very Happy
Got a mate having a look to see if he can find his, otherwise might pop down to local Landrover Dealership and see if they will reset it for me.
Post #572064 7th Nov 2020 12:15pm
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
hi what is old faithful reg would be nice thanks new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #572072 7th Nov 2020 1:47pm
range366
Old faithful reg number is SM52 ZXL
Post #572074 7th Nov 2020 2:04pm
range366
She drives brilliantly, never misses a beat and has wanted for nothing,.. but, and there's always a but.... she is gonna need a wee bit of work doing to her at some point, so I'm hoping someone prepared to take her on.
Post #572075 7th Nov 2020 2:12pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
I just brought a TDV8 2012 registered March 2013 so i think it may be one of the last of the L322's and i adore it my last one was a L322 TD6 i loved that too but this is a step up and so much better on Derv too Smile.
As for fueling now i have fixed the fuel gauge i find that if i lift the pump head i do not have any issues but if i let it rest it can be tricky.
Post #572077 7th Nov 2020 2:18pm
